Scalers with SVGA games?
First post, by DanielWolf
Hi everybody!
I have an LCD screen with 1280x1024 resulution. It would be great if I could play SVGA (640x480) games (Larry 7 etc.) with one of the advanced 2x scalers. However, I can't get these scalers to work on any game with a higher native resolution than VGA!
Is there any way to enable scalers for SVGA games?
Reply 1 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
use ykwnong builds that has the force scaler option.
Water flows down the stream
Reply 2 of 7, by DanielWolf
Hi Qbix,
thanks for your reply! Can you tell me where to find that "ykwnong" build? Google can't help me there...
(By the way: I'm using Windows.)
Reply 5 of 7, by DanielWolf
Hi Qbix, ykhwong!
I tried out the 04/10/2007 build with GUI. Using -forcescaler, I could get TV2x, Scan2x, and RGB2x to work. However, all the "interesting" scalers just resulted in a nearest pixel resize. Any hints?
Reply 6 of 7, by gulikoza
Use my build, set output to direct3d and try the new hq2x.fx pixelshader (make sure the scaler= is set to none) 😀
http://www.si-gamer.net/gulikoza
Reply 7 of 7, by DanielWolf
Hi gulikoza,
thanks for the tip! The 2xSaI.fx shader works just great!
Daniel
