First post, by =zum=
- Newbie
Hello, i've been interested by mt-32 possibility to display personalized text on LCD, so my first thought was to edit the .syx with notepad, but then, on my mt-32, appeared "exc. buffer overflow".
I've tried everything, even edit the sysex code by itself with midi-ox
For example:
F0 40 10 16 12 20 00 00 2A 20 53 50 41 43 45 20
51 55 45 53 54 20 49 49 49 20 2A 20 13 F7
Stands for " Space Quest 3 "
Now, for example the value 45 is "e" (i don't remember what really is), i change it to whatever, 43, that is supposed to be "c", any combinations i try, ends with the annoying "exc. buffer overflow", is there someway to display personalized text to mt-32 without failing?
And if i can't, you can explain me why?
Thanks.
