priority=???
First post, by depac_402
What effect do the priority settings in the conf file have?
I've tried different combinations in an attempt to figure it out but can't see any difference.
Maybe it's staring me straight in the face but I still don't get it 😊
# priority -- Priority levels for dosbox: lowest,lower,normal,higher,highest,pause (when not focussed).
# Second entry behind the comma is for when dosbox is not focused/minimized.
Reply 1 of 2, by MiniMax
Rank Moderator
Moderator
The priority sets the priority of DOSBox relative to all the other processes running on your system. If you are on Windows launch the Task Manager (Start => Run... => taskmgr). Go to the View meny => Choose columns => Base priority.
_________________
Reply 2 of 2, by depac_402
Got it!! Thanks 😀
