crash
First post, by Matrf
Hi all . I am tryn to play at fullthrotull . My sound is detected but when the game start it crash.
I see somekind of strange number just bellow the game graphics and the dos box or console close.
I have try whit no sound and its working , i have also try whit the other emulator link of the main page and its working.
I can't use launchpad yet , anyone got an idear?
Reply 1 of 16, by Matrf
Whit the launch pad and a lot of options change on i have succed to run the game!
I am about to send a compatibily report to vlad!
Reply 2 of 16, by Snover
What happened to your inability to use the Launchpad?
Yes, it’s my fault.
Reply 3 of 16, by Matrf
Vlad sent me the REG file so i can do it whiout using regvr32 but my problem whit registering dll still....No oneknow to fix that on all forum i have go , i think the only solution is to reinstall or maybe repair...
Reply 4 of 16, by Snover
You ran the "install.bat" as Admin, correct?
Yes, it’s my fault.
Reply 5 of 16, by Matrf
No , i ran the REG FILE .reg .
Vlad sent me it , the autoexec won't work . My resgvr32 is broken or somethings.
Reply 6 of 16, by Snover
It's REGSVR32.EXE, not REVSGR32.EXE.
You need to run the INSTALL.BAT file.
I've attached my REGSVR32.EXE. This is a Windows 2000 REGSVR32.EXE, so it probably won't work on XP.
Disclaimer: I am not responsible for anything that happens with this file. If it deletes your hard drive, you've done something terribly, terribly wrong, as regsvr32.exe doesn't have the ability to delete your hard drive. 😀
Yes, it’s my fault.
Reply 7 of 16, by Matrf
Its must be my english . I have already try to install a REGSVR32.EXE . Thanks for your help anyway.
Reply 8 of 16, by Snover
Perhaps this problem is being overanalysed.
Let's go back to the basics.
Are you using a LEGAL version of Windows?
Yes, it’s my fault.
Reply 9 of 16, by Matrf
yes , of windows2000
Reply 10 of 16, by Snover
Then insert the Windows 2000 CD, run SETUP.EXE (the one with the icon that doesn't look like a program window), and choose REPAIR!! C'mon, if an application that's installed by Windows isn't working correctly, it doesn't take a rocket scientist to think to repair their installation. Also try http://v4.windowsupdate.microsoft.com
Yes, it’s my fault.
Reply 11 of 16, by Matrf
Your flaming is annoying . Before reinstalling Windows i will look for a fix , i will not reintall windows for all problem . Install is the last solution.
Reply 12 of 16, by DonVincenzo
Oh my... my first post here, and a not so nice one, (of course feel free to delete away mods)
Look mate, you said yourself:
and then
Seems kinda odd to me, besides repairing your windows installation means... well means what that means, you won't lose anything by doing so, so maybe you will be nice enough to try that kind of fix, instead of abusing of all those (nice) guys kindness and (surely precious) time?
(The only positive thing I have to say is long live VDMSound, and well that forum, seems like a pretty nice place, heck if I'm not kicked out right now I might take place in one of the unused corner)
Reply 13 of 16, by Matrf
I said that i think its the only solution(I THINK = NOT SURE) , i said it myself that i know that reinstall is the last solution. And he almost tell me that i am stupid because he think i dont know that reinstall is a solution.
wow. COU COU !
Reply 14 of 16, by Snover
Repair IS NOT reinstall!! They're two completely different words, and they mean two completely different things!
Repair: Fixes broken files
Reinstall: Overwrites all files
Yes, it’s my fault.
Reply 15 of 16, by vladr
He doesn't have much choice. If it's a registry problem then repairing won't fix it (unless "repair" busts the registry, in which case might just as well reinstall).
Mathieu: I suspect something's broken either in the registry (permission/rights) or with ATL.DLL (used by all VDMSound DLL's when invoked by REGSVR32.EXE).
Make a test: close all Windows apps (that might use ATL.DLL), then rename ATL.DLL to ATL_DLL.OLD, and get ATL.DLL from the attached .zip file instead. ATL.DLL should be in the SYSTEM32 directory, although cached copy may be stored somewhere in C:\WINNT as well (do a search and rename all copies of ATL.DLL before extracting the .zip belo into SYSTEM32).
Try regsvr32.exe again with one of the dll's.
Cheers,
V.
Reply 16 of 16, by Snover
It would be cached in hidden folder C:\WINNT\SYSTEM32\DLLCACHE
Yes, it’s my fault.
