C&C Red Alert
First post, by DustinE
Ok i have got to get a way to run this game under windows 2000!
when i try to install it says that it cant work in NT 5.0
I have windows 2k with sp3 and a NTFS partition....
Reply 1 of 24, by Snover
Two Words: Compatibility mode.
Or, three words: Application Compatibility Toolkit.
Doesn't matter which one you use, just fake Win9x version number.
Yes, it’s my fault.
Reply 2 of 24, by Nicht Sehr Gut
Longer version from here:
1. Opened up my CD drive via My Computer. (right click on drive, and select open)
2. Right click on SETUP.EXE, and select "Properties."
3. Click on the compatibility tab, then click on the box that says, "Run this program in compatibility mode for," and select Windows 95.
Make sure you don't select Windows 98\ME, because of certain issues with Windows ME compatibility. The game works with Windows 98\ME compat. but the game will go slower and choppy.
4. Click Apply[if it appears] and then click OK.
5. Then open SETUP.EXE [the one you just did the compatibility thing with)
6. Install the game like normal. Viola! No more damn "Windows 5.1 detected..This game designed for Windows 95" crap. woohoo!
7. Go to this website: http://westwood.ea.com/html/techsupp/patches.html#ra
8. Click on the update that matches your language.
9. Download and install the above update.
10. Go to your Red Alert folder. (usually installed to C:\Westwood\Red Alert)
11. Right click on each of the following files, and click properties, then compatibility, then check the box, and then select Windows 95. (you will need to do this on each file individually) :
RA.exe
RA95.exe
RASetup.exe
RunGame.exe
RunMap.exe
EDWin.exe
12. Apply everything, and close out of everything.
13. Restart the computer.
14. Run the game with RA95.exe.
Reply 3 of 24, by Snover
Steps 11 and 13 seem highly un-necessary.
Yes, it’s my fault.
Reply 4 of 24, by Nicht Sehr Gut
Originally posted by Snover Steps 11 and 13 seem highly un-necessary.
*shrug*
Shouldn't hurt. Besides it was a complete copy of the original post, seems kind of rude to change it without a complete rewrite.
Reply 5 of 24, by DustinE
Application Compatibility Toolkit.. i have that and have it installed so huh how do i work it?
Reply 6 of 24, by Snover
I'm making a database fix for it, hold. The fuckers deleted QFixApp off my computer, I gotta find where I uploaded it, because apparently Compatibility Administrator doesn't actually work, and I'm still getting a Windows 5 error message.
Uh, yeah. Compatibility Administrator is shit and doesn't work.
So, yeah.
Get QFixApp and then use that to run the program. Should fix you up nicely.
Yes, it’s my fault.
Reply 7 of 24, by DustinE
how do i work this bloody thing!?!?
Reply 8 of 24, by Snover
*cough*
Step 1: Download.
Step 2: Unzip.
Step 3: Run.
Step 4: Select program to run.
Step 5: Click 'Run'.
or, Download Unzip Run Run Run.
*phew* that was tough.
Yes, it’s my fault.
Reply 9 of 24, by DustinE
Dont work...
Still Says:
it cant work on Windows 5.0
which is windows 2k 🙁
Reply 10 of 24, by Nicht Sehr Gut
DustinE wrote:
Dont work...
Still Says:
Did you try applying compatibility mode to the setup program before installing it as suggested in the third post?
Reply 11 of 24, by DustinE
There is not a compatiblity mode any where in any tab... yet i have windows 2k with SP3
Reply 12 of 24, by Snover
Not sure what to say, I tested it and it ran it fine with QFixApp. You need to Start > Run this in order to get compatibility tabs (and they only show up on SHORTCUTS, not on EXEs): "regsvr32 %WINDIR%\AppPatch\slayerui.dll"
Yes, it’s my fault.
Reply 13 of 24, by Nicht Sehr Gut
Originally posted by DustinE There is not a compatiblity mode any where in any tab... yet i have windows 2k with SP3
Then something's wrong at the OS-level. Win2K with SP3 should have a compatibility tab for every Windows executable.
Any other Win2K users know about this?
Reply 14 of 24, by Snover
Nicht, bad. Down. They only show up on SHORTCUTS, and only if you've registered the SlayerUI DLL.
Yes, it’s my fault.
Reply 15 of 24, by DustinE
Yiy Yiy, My everyone in my fam runs WIndows 2k (Pro or Adv. Server) but none of us have conmpatabily tabs.
I also tryed making a short cut... dont work.
Reply 16 of 24, by Nicht Sehr Gut
Snover [/i][B]Nicht, bad. Down. They only show up on SHORTCUTS,...[/quote] Hold on, soomeone's lying then...I saw somebody stating the opposite...and recently too... Hrmmm... I thought SP3 was supposed to do that for you... [quote][i]Originally posted by DustinE wrote:
Did you register the SlayerUI DLL like he said?
Reply 17 of 24, by MajorGrubert
DustinE, before anything else take a look at the \WINNT\AppPatch folder in your machine. It should be there if you have Windows 2000 SP3 and slayerui.dll must be there. If it is there, then run
regsvr32 slayerui.dll
You should get a dialog saying that the registration succeeded. If you got this far, create a shrotcut for any 32-bit Windows executable (\winnt\explorer.exe is fine) and look for the compatibility tab in the properties dialog for the shortcut. Remember that shortcuts for DOS or 16-bit Windows programs won't have the compatibility tab, since it only applies for 32-bit programs (Windows 95 or later).
Regards,
Major Grubert
Athlon 64 3200+/Asus K8V-X/1GB DDR400/GeForce FX 5700/SB Live! 5.1
Reply 18 of 24, by Nicht Sehr Gut
Originally posted by MajorGrubert Remember that shortcuts for DOS or 16-bit Windows programs won't have the compatibility tab, since it only applies for 32-bit programs (Windows 95 or later).
*Red Flag pops up*
*Nicht grabs Red Flag and caps it to win the game!*
*tumultuous applause*
Oh wait..."Red Flag" as in, I know there's a DOS version of "Red Alert" as well as the Win9x version. You're not trying to install the DOS version are you?
Reply 19 of 24, by DustinE
HOLY MOTHER... DANG! SWEET!! I see the tab!!
oh and the dos virson... only has 16 colors i want more!!!
Hey the windows Red Alert is installing!!
