Installing Full Throttle
First post, by Unregistered
Hi
I'm trying to install the game Full Throttle. The installation program seems to start just fine, but at the selection screen i cannot do anything (no mouse, no reaction to keyboard input). I'm not sure if it completely hangs, but it seems like it.
The installation program runs in what, to me, looks like 640x400
I'm on Windows XP
EDIT:SP1 - DX9a - GF2MX400 btw
Please help 😀
Reply 2 of 5, by Snover
Ignore the Unregistered user, Full Throttle's action engine has not been implemented.
Have not heard of this problem before. Will do some tests and get back to you.
Yes, it’s my fault.
Reply 3 of 5, by HunterZ
I just tried it and it worked for me, except that the sound stuttered for any option other than Sound Blaster (even Sound Blaster 2.0 stuttered severely - bye bye stereo 🙁). Here is what I did:
- Ran the install program on the CD with VDMSound (used the right-click command without the note)
- Chose Install
- Installed to D:\throttle
- Selected Sound Blaster for sound and did auto-detect (it is IMPORTANT that it detects IRQ 7 and NOT IRQ 5, or else it will be trying to use Windows' sound emulation instead of VDMSound's - if it detects IRQ 5 then you might need to disable Windows' sound emulation)
- Made a VDMSound LaunchPad shortcut to D:\THROTTLE\THROTTLE.EXE. Didn't see any options that I needed to change from the default.
- Ran the game. Menu appeared
- Hit Play. Game started.
I noticed that low-level CD-ROM support was not required to get the game to run, nor was "enable basic VESA" (starting in full-screen). The game says it needs at least 8MB of RAM, but doesn't say if it should be XMS, EMS, or DPMI. LaunchPad defaults to 16mb XMS and 4MB EMS (for whatever reason), so you may want to bump up the EMS to 8MB or 16MB just to be safe.
I just had a thought: maybe your problem is that you're one of those people who can't get EMS at all? You might try making a batch file (like test.bat) that contains the following:
mem
pause
Save it, create a launchpad shortcut to it, then run the shortcut and see how much EMS it reports (you can paste the results here if you want).
Also, so you know: I have a GF2MX, WinXP SP1, and DX9.0a, so none of those three things can be the problem unless something really funky is going on.
Reply 4 of 5, by MajorGrubert
HunterZ wrote:
I just tried it and it worked for me, except that the sound stuttered for any option other than Sound Blaster (even Sound Blaste […]
- Chose Install
I ran it fine with SoundBlaster 16, autodetected by the way. If you run the install program with VDMSound, autodetection should be trivial. If sound is sttutering, reduce the polling period in the Performance tab to something like 2 / 15 (min/max), if your CPU can handle it.
The game uses DMPI (DOS4/GW), so XMS and EMS are irrelevant. The defaults for a new shortcut should be fine.
At last, please give it a try with joystick emulation disabled. I had a consistent crash problem with Full Throttle and VDMSound until the day I disabled joystick emulation. After that, everything went fine.
Regards,
Major Grubert
Athlon 64 3200+/Asus K8V-X/1GB DDR400/GeForce FX 5700/SB Live! 5.1
