First post, by stimpy
Hi there,
next problem.. 😉
As I wrote in another post, I'm trying to install pcboard (bbs-software) in dosbox.
Everything's working just fine, but the "CONNECT" from the emulated modem of dosbox is coming to fast...
When I'm using syncterm-linux to connect to my bbs via telnet, pcboard receives a "RING", answers "ATA", but the modem answers "CONNECT 57600" too fast, so pcboard does'nt recognize.
When entering "CONNECT 57600" manually and blind at syncterm, pcboard recognizes and the session starts...
So.. Is there a way to add a delay between "ATA" and the modems answer...?
Feel free to try it yourself: host: elyzium.ath.cx port: 2323 .. 😀
Regards,
stimpy
Reply 1 of 1, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
If your terminal supports some sort of "already connected" you could try the nullmodem (parameters are explained in readme). Yes, that modem does need some more improvement...
1+1=10
