Sound Packs
First post, by Solo
I installed the sound pack from Glidos. It is interesting to be able to hear the dialogs in the cutscenes again. Some of the music is interesting. Quite different than when I originally played the game with Windows 95.
However...I really miss the original special sounds and sound change when the T-Rex is triggered in Lost Valley. 🙁
Nathan McCree's sound pack is interesting, but has anyone else created a sound pack for TR1 ?
Solo.
Reply 1 of 2, by Kaminari
Nathan McCree is not the author of the pack. He's the original composer of the TR1 soundtrack.
What you're hearing in this pack is a mix between the DOS and the Saturn/PS1 versions. The hardest part is restoring in the DOS version the many musical cues from the console versions which were not present in the DOS version. That's why this pack is made by several people and is a work in progress.
Reply 2 of 2, by Solo
Ah!...I see. Well...Mr McCree did a nice job on the soundtrack.
And the audio pack is also pretty good, over-all.
I just sort of miss hearing that special sound change that tells Lara to run like blazes. 🤣
