Changing cycles
First post, by carcass
How do I change the "cycles" so I can run Quarantine? I have Dosbox 0.65 on Mac OS X.
Right now Quarantine runs too fast and I can't even navigate. Then it crashes. If there's another way I can solve this problem please let me know because this is my #1 favourite game of all time.
Reply 1 of 5, by leileilol
you mean you didn't read "If you want more speed, try ctrl-F8 and ctrl-F12." right when you start DOSbox?
long live PCem
Reply 2 of 5, by ErikGG
It is also recommended to upgrade to 0.71.
Erik.
Read the new FAQ.doc
Reply 3 of 5, by carcass
The thing is I have too much speed.
Reply 4 of 5, by carcass
Correction, it works now. It's a little choppy but I'll figure out a good setting.
Now if anyone can remind me how to turn fullscreen on,
Reply 5 of 5, by MiniMax
Rank Moderator
Moderator
If you open and read the file called (Ta Da!) README.TXT, then after 5 minutes your screen will automatically switch to full screen. Or maybe not.
_________________
