First post, by Buffy
hi,
i really tried. i checkt all the guides and used the newbie guide. i created dos box file and oldgames on C:
i mount C to oldgames ( it worked since when i try again it tells me that C oldgames is already C)
then i tried to open kelloggsland, the setup is in that file, in oldgames. but when i type C: and the kelloggsland it always tells me illegal commant.
please help me, dos is just too long ago and i was too young.
thank you so much! i cant wait to play kellogg's land again:)
Reply 1 of 19, by DosFreak
You need to tell us EXACTLY what you type in when you start DosBox.
It should be:
Mount c c:\Games
c:
Then you type in "CD Kellog" to enter the game directory.
Then you type in the name of the game executable to launch the game.
I do not have the game so I do not know the proper name of it or if you need to run a setup program to configure the sound.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 19, by Buffy
thank you for answering
mount C C:\oldgames
then C:
then Z changed to C
then i tried to open the file i created in oldgames that i called kelloggsland
i typed in: kelloggsland
then: command illegal
shouldnt it just open the file first. i put the setup in this file so i thought i just open the file, and then try setup.exe
Reply 3 of 19, by DosFreak
If you use "Kelloggsland" then that is too long of a name for DOSBox.
DOSBox only recognizes 8.3 character filenames.
So you need to change "Kelloggsland" to "Kelloggs".
Reply 5 of 19, by DosFreak
Did you change the name of the folder in Windows? Try changing it to just "k" and then go to "k".
ex:
mount c c:\oldgames
c:
cd k
Reply 9 of 19, by eL_PuSHeR
Rank Moderator
Moderator
You need to use CORE=NORMAL.
    5.97 KiB
    72.93 KiB
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 11 of 19, by eL_PuSHeR
Rank Moderator
Moderator
I don't know why the second capture is borked. It showed fine when playing, though.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 13 of 19, by eL_PuSHeR
Rank Moderator
Moderator
You are probably right as I played for just 10 seconds. I was using fixed cycles though. Where can I get your demovga build version?
Intel i7 5960X
8 GB DDR4 (2100)
Reply 16 of 19, by pandora
Hi! I encountered the same problem and did what was told (re: changing the name 'coz it's too long). I tried to mount it again using the new name but it said that the game was already mounted, so I typed in:
E:\>cd TH
Unable to change to TH
I also tried cd: TH\TH.exe
(TH.exe is at TH folder at drive E)
I do not know really if I missed something, consider me $T%&iD when it comes to pc technicalities or whatever. I'm going crazy for 2days now and I haven't got any sleep since yesterday. All I wanted was to play that old game. Please help.
Thanks in advance!
Reply 17 of 19, by pandora
when I tried to mount it again it said:
Drive already mounted with local directory E:\ThemeHospital\
Direcoryname is longer than 8.3 characters and/or contains spaces.
Try cd TH\The~1
E:\>cd TH\The~1
Unable to change to: TH\The~1
Reply 19 of 19, by pandora
Hi! Thank you for the prompt reply. I followed the instruction at Wiki and didn't see the "dir" thing (didn't finish reading the entire page 'coz I was so excited to play), but will take your advice for sure. Will let you know what happens.
Thanks again!
