First post, by Krook
Hi there. I'm having real problems running the original game using glidos in XP, it's just not happening!
I've read a few guides etc as to how to get it working using the various tools but it makes absolutely no difference. I've even tried using two different graphics cards complete with updated drivers (audio as well) but still the same. I've exhausted the possible settings and made sure VDMsound is correctly installed as that seems quite important, but to no avail.
When it starts I see the VDMsound driver initiate fine and then it just fails once the "gldvesa.exe tomb.exe" command line takes place. This message is then shown:
I have tried Glidos versions 1.28, 1.35 & 1.38 as well as DgVoodoo 1.31 & 1.40+, all have the same problem.
Haven't a clue where to go from here so if anyone has any suggestions then it will be greatly appreciated. I've almost given up on it all... the game that is!
Here's the diagnostics report:
Diagnostic tool developed for http://www.tombraiderforums.com
Version : 2.44
Author : Simulation
Select All (Ctrl A) then Copy (Ctrl C) and paste (Ctrl V) the text in Notepad into a reply on the forum.
Operating System
Windows XP Detected[b]COMMAND.COM[/b]COMMAND.COM has been installed[b]Autoexec.NT [/b]@echo offlh %SystemRoot%\system32\mscdexnt.exelh %SystemRoot%\system32\redirlh %SystemRoot%\system32\dosxSET BLASTER=A220 I5 D1 P330 T3[b]Config.NT[/b]dos=high, umbdevice=%SystemRoot%\system32\himem.sysfiles=40[b]Programs Currently Running[/b]Image Name PID Session Name Session# Mem Usage========================= ====== ================ ======== ============System Idle Process 0 Console 0 20 KSystem 4 Console 0 224 Ksmss.exe 468 Console 0 344 Kcsrss.exe 536 Console 0 3,828 Kwinlogon.exe 560 Console 0 3,608 Kservices.exe 604 Console 0 2,720 Klsass.exe 616 Console 0 1,188 Ksvchost.exe 784 Console 0 2,548 Ksvchost.exe 808 Console 0 16,844 Ksvchost.exe 892 Console 0 1,668 Ksvchost.exe 904 Console 0 2,944 Kexplorer.exe 1160 Console 0 8,424 Kspoolsv.exe 1220 Console 0 3,388 Kalg.exe 1324 Console 0 3,148 Kavgamsvr.exe 1336 Console 0 196 Kavgupsvc.exe 1352 Console 0 688 Knvsvc32.exe 1400 Console 0 3,204 Kavgcc.exe 1772 Console 0 232 Kavgemc.exe 1780 Console 0 1,676 Kdragdiag.exe 1804 Console 0 2,640 Kjusched.exe 1820 Console 0 2,008 Krundll32.exe 1860 Console 0 2,548 KSOUNDMAN.EXE 1888 Console 0 2,068 Kctfmon.exe 1900 Console 0 2,344 Kmsmsgs.exe 1928 Console 0 4,364 KGoogleToolbarNotifier.exe 2004 Console 0 1,020 Kraid_tool.exe 208 Console 0 3,320 Kiexplore.exe 1876 Console 0 4,444 Ksvchost.exe 1212 Console 0 2,576 Kdiagnose.exe 1956 Console 0 3,328 Kns26.tmp 716 Console 0 732 Kcmd.exe 252 Console 0 1,080 Ktasklist.exe 1948 Console 0 2,852 Kwmiprvse.exe 656 Console 0 3,776 K
System Event Log - Warning and Errors Only (last 24hrs)
Event Log from 08:00am on the 26/08/2007------------------------------------------------------------------------------Listing the events in 'application' log of host 'SAM-I7HA11JK0S4'------------------------------------------------------------------------------Type Event Date Time Source ComputerName Category User Description------------- ------ ------------------------ ----------------- -------------- --------------- -------------------- ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
Tomb Raider Game Setup Information
[b][SIZE="3"][COLOR="Blue"][U]Tomb Raider 1 Installed[/U][/COLOR][/SIZE][/b]TOMB.EXE File Size = 873739 bytes - Glide Emulator version installed by ATR Installer[b]trai.dat[/b][TRUB]TRAIVersion=1.0.6.92OpticalDevice=D:\UseGlidos=TrueGlidosFolder=C:\Program Files\Glidos\UseDgVoodoo=FalseDgVoodooVersion=Not configuredDgVoodooVDDMode=Not configuredUseVDMSound=TrueVDMSoundVersion=2.1.0VDMSoundFolder=C:\Program Files\VDMSound\VDMSoundType=StereoVDMSoundIRQ=7SetAffinity=FalseDesktopShortcut=Not configuredPifShortcut=C:\TOMBRAID\TOMBUB.PIF[b]hmiset.cfg[/b][DIGITAL]DeviceName = Sound Blaster 16/AWE32DeviceIRQ = 7DeviceDMA = 1DevicePort = 0x220DeviceID = 0xe016[MIDI]DeviceName = No MIDI DeviceDevicePort = 0xffffffffDeviceID = 0xffffffff[b]NTVDM.EXE .COM[/b]NTVDM.EXE has been installed[b]VDMSound[/b]VDMSound Version = 2.1.0 Installed in C:\Program Files\VDMSound[SB Controller]CLSID = EmuSBCompat.SBCompatCtlPath = EmuSBCompat.dll[SB Controller.depends]VDMSrv = VDMServicesProviderDMACtl = DMA Transfer ManagerWaveOut = SB Wave PlayerAdLib = AdLib Controller[SB Controller.config]version = 4.15 ; 1.05 for SB1.x, 2.01 for SB2, 3.02 for SBPro, 4.05 for SB16port = 0x220 ; usually 0x220 (can also be 210, 230, 240, 250, 260 or 280)IRQ = 7 ; usually 5 or 7DMA8 = 1 ; usually 1DMA16 = 5 ; usually 5;; forceSampleRate = 22050;; forceNumBits = 16
;; forceChannels = 2[b]VLP Files on Desktop[/b]VLP files are NOT present on Desktop[b]VLP Files in C:\TOMBRAID[/b]VLP files are NOT present in c:\tombraid[b][SIZE="3"][COLOR="Blue"][U]Tomb Raider 1 Gold - Unfinished Business Installed[/U][/COLOR][/SIZE][/b]TOMBUB.EXE File Size = 867563 bytes - Glide Emulator version installed
DirectX Diagnostics Report
------------------System Information------------------Time of this report: 8/27/2007, 14:05:33Machine name: SAM-I7HA11JK0S4Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 1 (2600.xpsp1.020828-1920)Language: English (Regional Setting: English)System Manufacturer: VIAK8_System Model: AWRDACPIBIOS: Award Modular BIOS v6.00PGProcessor: AMD Sempron(tm) Processor 3100+, ~1.8GHzMemory: 1024MB RAMPage File: 221MB used, 2241MB availableWindows Dir: C:\WINDOWSDirectX Version: DirectX 9.0c (4.09.0000.0904)DX Setup Parameters: Not foundDxDiag Version: 5.03.0001.0904 32bit Unicode------------DxDiag Notes------------DirectX Files Tab: No problems found.Display Tab 1: No problems found.Sound Tab 1: No problems found.Music Tab: No problems found.Input Tab: No problems found.Network Tab: No problems found.--------------------DirectX Debug Levels--------------------Direct3D: 0/4 (n/a)DirectDraw: 0/4 (retail)DirectInput: 0/5 (n/a)DirectMusic: 0/5 (n/a)DirectPlay: 0/9 (retail)DirectSound: 0/5 (retail)DirectShow: 0/6 (retail)---------------Display Devices---------------Card name: NVIDIA GeForce FX 5700LEManufacturer: NVIDIAChip type: GeForce FX 5700LEDAC type: Integrated RAMDACDevice Key: Enum\PCI\VEN_10DE&DEV_0343&SUBSYS_00000000&REV_A1Display Memory: 128.0 MBCurrent Mode: 1024 x 768 (32 bit) (70Hz)Monitor: Plug and Play MonitorMonitor Max Res: 1600,1200Driver Name: nv4_disp.dllDriver Version: 6.14.0011.6218 (English)DDI Version: 9 (or higher)Driver Attributes: Final RetailDriver Date/Size: 6/29/2007 00:43:00, 5690624 bytesWHQL Logo'd: n/aWHQL Date Stamp: n/aVDD: n/aMini VDD: nv4_mini.sys
Mini VDD Date: 6/29/2007 00:43:00, 6807328 bytesDevice Identifier: {D7B71E3E-4003-11CF-FA7B-0B2000C2CB35}Vendor ID: 0x10DEDevice ID: 0x0343SubSys ID: 0x00000000Revision ID: 0x00A1Revision ID: 0x00A1Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_DDeinterlace Caps: {212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretchRegistry: OKDDraw Status: EnabledD3D Status: EnabledAGP Status: EnabledDDraw Test Result: Not runD3D7 Test Result: Not runD3D8 Test Result: Not runD3D9 Test Result: Not run-------------Sound Devices-------------Description: Realtek AC97 AudioDefault Sound Playback: YesDefault Voice Playback: YesHardware ID: PCI\VEN_1106&DEV_3059&SUBSYS_A0021458&REV_60Manufacturer ID: 1Product ID: 100Type: WDMDriver Name: ALCXWDM.SYSDriver Version: 5.10.0000.6250 (English)Driver Attributes: Final RetailWHQL Logo'd: n/aDate and Size: 8/7/2007 18:33:00, 4108992 bytesOther Files:Driver Provider: Realtek Semiconductor Corp.HW Accel Level: FullCap Flags: 0x0Min/Max Sample Rate: 0, 0Static/Strm HW Mix Bufs: 0, 0Static/Strm HW 3D Bufs: 0, 0HW Memory: 0Voice Management: NoEAX(tm) 2.0 Listen/Src: Yes, YesI3DL2(tm) Listen/Src: Yes, YesSensaura(tm) ZoomFX(tm): NoRegistry: OKSound Test Result: Not run---------------------Sound Capture Devices---------------------Description: Realtek AC97 AudioDefault Sound Capture: YesDefault Voice Capture: YesDriver Name: ALCXWDM.SYSDriver Version: 5.10.0000.6250 (English)Driver Attributes: Final RetailDate and Size: 8/7/2007 18:33:00, 4108992 bytesCap Flags: 0x0Format Flags: 0x0-----------DirectMusic-----------DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLSDLS Version: 1.00.0016.0002Acceleration: n/aPorts: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default PortRealtek AC97 Audio, Software (Kernel Mode), Output, DLS, InternalMicrosoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, InternalMicrosoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, InternalRegistry: OKTest Result: Not run-------------------DirectInput Devices-------------------Device Name: MouseAttached: 1Controller ID: n/aVendor/Product ID: n/aFF Driver: n/aDevice Name: KeyboardAttached: 1Controller ID: n/aVendor/Product ID: n/aFF Driver: n/aPoll w/ Interrupt: NoRegistry: OK-----------USB Devices-----------+ USB Root Hub| Vendor/Product ID: 0x1106, 0x3038| Matching Device ID: usb\root_hub| Service: usbhub| Driver: usbhub.sys, 8/29/2002 01:32:50, 51968 bytes| Driver: usbd.sys, 8/23/2001 13:00:00, 4736 bytes----------------Gameport Devices----------------------------PS/2 Devices------------+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard| Matching Device ID: *pnp0303| Service: i8042prt| Driver: i8042prt.sys, 8/29/2002 02:06:38, 51072 bytes| Driver: kbdclass.sys, 8/29/2002 01:27:02, 23424 bytes|+ Terminal Server Keyboard Driver| Matching Device ID: root\rdp_kbd| Upper Filters: kbdclass| Service: TermDD| Driver: termdd.sys, 8/29/2002 03:46:42, 38024 bytes| Driver: kbdclass.sys, 8/29/2002 01:27:02, 23424 bytes|+ PS/2 Compatible Mouse| Matching Device ID: *pnp0f13| Service: i8042prt| Driver: i8042prt.sys, 8/29/2002 02:06:38, 51072 bytes| Driver: mouclass.sys, 8/29/2002 01:27:02, 22016 bytes|+ Terminal Server Mouse Driver| Matching Device ID: root\rdp_mou| Upper Filters: mouclass| Service: TermDD| Driver: termdd.sys, 8/29/2002 03:46:42, 38024 bytes| Driver: mouclass.sys, 8/29/2002 01:27:02, 22016 bytes----------------------------DirectPlay Service Providers----------------------------DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0001.0904)IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0001.0904)Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not runDirectPlay Test Result: Not runRegistry: OK-------------------DirectPlay Adapters-------------------DirectPlay8 Modem Service Provider: Generic 56K HCF Data Fax ModemDirectPlay8 Serial Service Provider: COM1DirectPlay8 Serial Service Provider: COM2DirectPlay8 Serial Service Provider: COM3DirectPlay8 TCP/IP Service Provider: Tiscali Broadband - IPv4 ------------------------DirectPlay Voice Codecs-----------------------Voxware VR12 1.4kbit/sVoxware SC06 6.4kbit/sVoxware SC03 3.2kbit/sMS-PCM 64 kbit/sMS-ADPCM 32.8 kbit/sMicrosoft GSM 6.10 13 kbit/sTrueSpeech(TM) 8.6 kbit/s-------------------------DirectPlay Lobbyable Apps-------------------------------------------------Disk & DVD/CD-ROM Drives------------------------Drive: C:Free Space: 49.6 GBTotal Space: 76.3 GBFile System: NTFSModel: ST380011ADrive: D:Model: SONY DVD RW DW-D22ADriver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.1106 (English), 8/29/2002 01:27:56, 47488 bytesDrive: E:Model: ATAPI DVD A DH20A3PDriver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.1106 (English), 8/29/2002 01:27:56, 47488 bytes--------------System Devices--------------Name: Generic 56K HCF Data Fax ModemDevice ID: PCI\VEN_14F1&DEV_1034&SUBSYS_1016144F&REV_08\3&13C0B0C5&0&50Driver: n/aName: VIA CPU to AGP2.0/AGP3.0 ControllerDevice ID: PCI\VEN_1106&DEV_B188&SUBSYS_00000000&REV_00\3&13C0B0C5&0&08Driver: C:\WINDOWS\System32\DRIVERS\VIAAGP1.SYS, 5.01.0000.3442 (English), 7/1/2003 21:42:00, 27904 bytesName: VIA Standard Host BridgeDevice ID: PCI\VEN_1106&DEV_7282&SUBSYS_00000000&REV_00\3&13C0B0C5&0&07Driver: n/aName: VIA Standard Host BridgeDevice ID: PCI\VEN_1106&DEV_4282&SUBSYS_00000000&REV_00\3&13C0B0C5&0&04Driver: n/aName: VIA Standard Host BridgeDevice ID: PCI\VEN_1106&DEV_3282&SUBSYS_00000000&REV_00\3&13C0B0C5&0&03Driver: n/aName: VIA Standard PCI to ISA BridgeDevice ID: PCI\VEN_1106&DEV_3227&SUBSYS_00000000&REV_00\3&13C0B0C5&0&88Driver: C:\WINDOWS\System32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 13:58:02, 35840 bytesName: VIA SATA RAID ControllerDevice ID: PCI\VEN_1106&DEV_3149&SUBSYS_B0031458&REV_80\3&13C0B0C5&0&78Driver: C:\WINDOWS\System32\DRIVERS\viamraid.sys, 5.01.2600.0310 (English), 5/18/2004 09:55:26, 74112 bytesName: Standard Enhanced PCI to USB Host ControllerDevice ID: PCI\VEN_1106&DEV_3104&SUBSYS_50041458&REV_86\3&13C0B0C5&0&84Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:50, 19328 bytesDriver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:52, 135552 bytesDriver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:50, 51968 bytesDriver: C:\WINDOWS\System32\hccoin.dll, 5.01.2600.1106 (English), 8/29/2002 03:40:56, 5120 bytesDriver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (English), 8/17/2001 23:36:34, 67072 bytesName: Realtek AC'97 Audio for VIA (R) Audio ControllerDevice ID: PCI\VEN_1106&DEV_3059&SUBSYS_A0021458&REV_60\3&13C0B0C5&0&8DDriver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:34, 57856 bytesDriver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.1106 (English), 8/29/2002 02:01:00, 134272 bytesDriver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.0001.0904 (English), 7/9/2004 04:27:28, 48512 bytesDriver: C:\WINDOWS\System32\wdmaud.drv, 5.01.2600.0000 (English), 8/17/2001 22:37:04, 22016 bytesDriver: C:\WINDOWS\System32\ksuser.dll, 5.03.0000.0900 (English), 12/12/2002 00:14:32, 4096 bytesDriver: C:\WINDOWS\system32\drivers\ALCXWDM.SYS, 5.10.0000.6250 (English), 8/7/2007 18:33:00, 4108992 bytesDriver: C:\WINDOWS\SOUNDMAN.EXE, 5.01.0000.0059 (English), 4/16/2007 15:28:00, 577536 bytesDriver: C:\WINDOWS\System32\ALSNDMGR.CPL, 2.02.0000.0073 (English), 11/17/2006 05:40:00, 18804736 bytesDriver: C:\WINDOWS\System32\ALSNDMGR.WAV, 2/5/2002 13:54:00, 141016 bytesDriver: C:\WINDOWS\System32\RTLCPL.EXE, 1.00.0001.0066 (English), 12/8/2006 15:20:00, 10528768 bytesDriver: C:\WINDOWS\System32\RTLCPAPI.dll, 1.00.0001.0004 (English), 10/18/2006 02:53:00, 147456 bytesDriver: C:\WINDOWS\Alcrmv.exe, 2.00.0000.0004 (English), 7/31/2006 11:27:00, 217088 bytesName: VIA Rev 5 or later USB Universal Host ControllerDevice ID: PCI\VEN_1106&DEV_3038&SUBSYS_50041458&REV_81\3&13C0B0C5&0&83Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:50, 19328 bytesDriver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:52, 135552 bytesDriver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:50, 51968 bytesDriver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (English), 8/17/2001 23:36:34, 67072 bytesName: VIA Rev 5 or later USB Universal Host ControllerDevice ID: PCI\VEN_1106&DEV_3038&SUBSYS_50041458&REV_81\3&13C0B0C5&0&82Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:50, 19328 bytesDriver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:52, 135552 bytesDriver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:50, 51968 bytesDriver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (English), 8/17/2001 23:36:34, 67072 bytesName: VIA Rev 5 or later USB Universal Host ControllerDevice ID: PCI\VEN_1106&DEV_3038&SUBSYS_50041458&REV_81\3&13C0B0C5&0&81Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:50, 19328 bytesDriver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:52, 135552 bytesDriver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:50, 51968 bytesDriver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (English), 8/17/2001 23:36:34, 67072 bytesName: VIA Rev 5 or later USB Universal Host ControllerDevice ID: PCI\VEN_1106&DEV_3038&SUBSYS_50041458&REV_81\3&13C0B0C5&0&80Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:50, 19328 bytesDriver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:52, 135552 bytesDriver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:50, 51968 bytesDriver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (English), 8/17/2001 23:36:34, 67072 bytesName: VIA Standard Host BridgeDevice ID: PCI\VEN_1106&DEV_2282&SUBSYS_00000000&REV_00\3&13C0B0C5&0&02Driver: n/aName: VIA Standard Host BridgeDevice ID: PCI\VEN_1106&DEV_1282&SUBSYS_00000000&REV_00\3&13C0B0C5&0&01Driver: n/aName: VIA Bus Master IDE ControllerDevice ID: PCI\VEN_1106&DEV_0571&SUBSYS_50021458&REV_06\3&13C0B0C5&0&79Driver: C:\WINDOWS\System32\DRIVERS\viaidexp.sys, 5.01.2600.0120 (English), 10/18/2001 05:00:00, 6144 bytesName: VIA Standard Host BridgeDevice ID: PCI\VEN_1106&DEV_0282&SUBSYS_00000000&REV_00\3&13C0B0C5&0&00Driver: n/aName: Realtek RTL8139/810x Family Fast Ethernet NICDevice ID: PCI\VEN_10EC&DEV_8139&SUBSYS_E0001458&REV_10\3&13C0B0C5&0&98Driver: C:\WINDOWS\System32\DRIVERS\Rtlnicxp.sys, 5.620.1202.2004 (English), 12/2/2004 09:36:08, 70912 bytesName: NVIDIA GeForce FX 5700LEDevice ID: PCI\VEN_10DE&DEV_0343&SUBSYS_00000000&REV_A1\4&26E5F5CD&0&0008Driver: C:\WINDOWS\System32\DRIVERS\nv4_mini.sys, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 6807328 bytesDriver: C:\WINDOWS\System32\nv4_disp.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 5690624 bytesDriver: C:\WINDOWS\System32\nvsvc32.exe, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 155716 bytesDriver: C:\WINDOWS\System32\nvapi.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 360448 bytesDriver: C:\WINDOWS\System32\nvucode.bin, 6/29/2007 00:43:00, 1018772 bytesDriver: C:\WINDOWS\System32\nvoglnt.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 6729728 bytesDriver: C:\WINDOWS\System32\nvcpl.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 8466432 bytesDriver: C:\WINDOWS\System32\nvmctray.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 81920 bytesDriver: C:\WINDOWS\System32\nvwddi.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 81920 bytesDriver: C:\WINDOWS\System32\nvnt4cpl.dll, 6.14.0010.12002 (English), 6/29/2007 00:43:00, 286720 bytesDriver: C:\WINDOWS\System32\nvmccs.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 229376 bytesDriver: C:\WINDOWS\System32\nvdisps.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 6234112 bytesDriver: C:\WINDOWS\System32\nvdispsr.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 5455872 bytesDriver: C:\WINDOWS\System32\nvgames.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 3321856 bytesDriver: C:\WINDOWS\System32\nvgamesr.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 3072000 bytesDriver: C:\WINDOWS\System32\nvmccss.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 188416 bytesDriver: C:\WINDOWS\System32\nvmccssr.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 458752 bytesDriver: C:\WINDOWS\System32\nvmobls.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 1142784 bytesDriver: C:\WINDOWS\System32\nvmoblsr.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 2854912 bytesDriver: C:\WINDOWS\System32\nvvitvs.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 3518464 bytesDriver: C:\WINDOWS\System32\nvvitvsr.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 3600384 bytesDriver: C:\WINDOWS\System32\nvwss.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 2330624 bytesDriver: C:\WINDOWS\System32\nvwssr.dll, 6.14.0011.6218 (English), 6/29/2007 00:43:00, 2416640 bytesDriver: C:\WINDOWS\help\nvcpl.hlp, 6/29/2007 00:43:00, 177897 bytesDriver: C:\WINDOWS\help\nvwcplen.hlp, 6/29/2007 00:43:00, 55444 bytesDriver: C:\WINDOWS\System32\nvcod.dll, 1.00.0000.0035 (English), 6/29/2007 00:43:00, 37376 bytesDriver: C:\WINDOWS\System32\nvcodins.dll, 1.00.0000.0035 (English), 6/29/2007 00:43:00, 37376 bytesName: PCI standard host CPU bridgeDevice ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&13C0B0C5&0&C3Driver: n/aName: PCI standard host CPU bridgeDevice ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&13C0B0C5&0&C2Driver: n/aName: PCI standard host CPU bridgeDevice ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&13C0B0C5&0&C1Driver: n/aName: PCI standard host CPU bridgeDevice ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&13C0B0C5&0&C0Driver: n/a------------------
Thanks.
