First post, by lightningsimon
Hi all, I am trying to network an old strategy game called M.A.X. (Mechanized Assault and Exploration) but when I want to host a network game it asks me to please insert the CD.
I don't have the CD, I only have the unpacked items on my c drive.. What should I do? Thanks!
Reply 1 of 8, by eL_PuSHeR
Ugh, so where did you installed it from?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 8, by lightningsimon
I got a zipfiel with the unpacked files from a friend (normally need to run the installer from the cd).
So I am thinking that even if I would burn these unpacked files on cd the game would not recognize it as the orginal cd.. but I have no idea..
Reply 3 of 8, by ADDiCT
Works perfectly with the original CD.
Reply 4 of 8, by lightningsimon
well the last time I played it was more than 5 years ago and I have lost the original cd..
Reply 5 of 8, by wd
Rank DOSBox Author
DOSBox Author
Well if the game *needs* the cd and you don't have it, you're out
of luck anyways. Otherwise you can try something like "mount d c:\oldstuff\maxcd -t cdrom"
Reply 6 of 8, by lightningsimon
well actually, to really make it clear.. I am not even sure if I lost the cd, I have been living in bangkok for the last two years and the cd is probably somewhere in my house back in amsterdam.. but that doesnt really help me..- if i still have it.
Anyway can someone help me witht the problem? Would be really appreciated!! thanks in advance 😀
Reply 7 of 8, by lightningsimon
Would that mean that i mount the folder in which I have the game files as a cd drive? cause i have tried that.. only in my case the folder is c:\max . you are tlaking about that right?
As far as i know the game only "needs" the cd the verify ownership. When I used to play it on multiple computers it also worked.
Reply 8 of 8, by wd
Rank DOSBox Author
DOSBox Author
Well it depends on what it needs from the cd. If it's just some files, then mounting
the directory that contains the full cdrom-contents will suffice, if it directly reads
out sectors you need the real thing (or an image of it).
