First post, by badassb
I'm having a bit of a problem. I just reinstalled Windows (XP sp2, all up to date with updates and what not), and everything is working well. Except DOSBox. For some reason, when I load it up it has a biiiiiiiiiiiig pause. It ties up my cpu in a major way, causes my whole system to pause for a good ten to fifteen seconds while it loads itself up. Now, I've tried it with 0.72, and also with 0.62 I think, or 0.63 whatever came with the Space Quest Collection, and it's the same thing every time. I haven't had this issue before this most recent installation of Windows. For the record, I'm running an AMD 2ghz dual core processor with 1.5gb ram, anything else you think you need to know, lemme know. Thanks for any help you can give!
