Dos Sound
First post, by Pied Piper
Ive been using the DosBox and VDMS programs to run the games, Kyradia 2, Gabriel knight 1, Kings Quest 6 and 7. But i cant get any speach/voices out of the games, the music works at midi but i cant get the voices. What do i do????
Can someone Pleassse help me ive read heaps of threads but have hit a massive brick wall.size=12][/size]
Reply 1 of 3, by eL_PuSHeR
You may need to set up games accordingly with the sound card emulated in DOSBox. Also, some games need to be run using very low cycles for soundcard autodetection to work.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 3, by Sephiroth
KQ6 and 7 work fine, you need to runt heir setup programs and enter the soundcard info for the card you are using. I normally run an SB16 soundcard with the settings my real 486SX has for its SB16 card. If you're using the GUS or Roland, you'll have to see what settings they use and choose those in the setup program.
486 Launcher v2.0 is now under development!
