First post, by DoctorKazefa
Hi all,
(I'm currently typing this from my laptop.)
I installed MechWarrior 2 on my home computer using this IBM CD through some obscure process that I seriously can't remember. I should be able to follow the same process on this computer, but I can't recall what to do.
I know that I used DOSBOX after installation to get the game running, but that's not my problem -- I can't even install the game!
* Motherboard - Stock ASUS
* Processor type and speed - Intel Duo T5500
* Amount and type of RAM - 1GB (type unknown)
* Video board w/ RAM amount and type - Integrated Mobile Intel 945GM
* Sound board - integrated
* Operating system - Win XP Pro
* Game name (and version, if applicable) - MechWarrior 2 IBM CD version
* Version of emulator (for VDMSound, probably 2.0.4 or 2.1.0; for DOSBox, 0.58+) - once it gets working, DOSBox 0.72
Things tried - running without compatibility mode, running with compatibility mode, copying all files to hard drive and trying to run the install (failed because MW2 needs to be loaded from the CD). I would like to see if i can install the game in DOS but my DOS boot disk isn't working for some reason.
I would love any suggestions or comments. Thanks!
Reply 1 of 6, by MiniMax
Rank Moderator
Moderator
What??? You want to use DOSBox 0.72 once it gets working? But if it works, why use DOSBox 0.72?
_________________
Reply 2 of 6, by ADDiCT
??? Don't post when you're drunk... (;
DoctorKazefa: install the game from within DOSBox. You don't need DOS disks, as DOSBox emulates a DOS environment. Read the readme and the guides here to find out how to mount drives etc.
Basic steps:
- Install DOSBox
- Mount virtual drive c: (and CDROM)
- Install game
- Setup game (sound, etc.)
- Run game! (;
That's when using the DOS version of MW2, of course. According to MobyGames, there are also Windows variants of the game. These won't work with DOSBox, obviously.
Reply 3 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
mechwarrior 2 => use iso or cue/bin with imgmount else cdrom detection fails
Water flows down the stream
Reply 4 of 6, by DoctorKazefa
Hey guys,
@Qbix - imgmount as in imgmount the dosbox command? cool, I'll try that.
@Addict - I tried installing in DOSBox but I receive an error:
Error Code 9005
The installer was unable to find a suitable temporary directory.
@MiniMax - nonono, what I mean is, I can only play the game through dosbox. However I install it, that's how I have to play it.
After reading this I tried: install.exe SwapDir=c:\misc
and received the same error! (although the code had shifted to 9009).
(Am I missing something here?)
Thanks!
Reply 5 of 6, by DoctorKazefa
Hey everyone,
Thanks for your help! I got the game working.
What I did in the end was:
mount c c:\games
imgmount o c:\mw2.bin -t iso (thanks qbit!)
(I had to make mw2.bin, the image file of my MW2 cd.)
I could then run the install program, and then mech2.
Amazing, this brings back so many memories =)
Again thanks!
Reply 6 of 6, by eL_PuSHeR
[Moved]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
