First post, by ErikGG
It seems there is a piece missing of the right side of the screen running Albion with a scaler other then the normalxx scalers.
Tried DOSBox 0.65 and up
With all output devices.
With aspect ratio on and off.
All resolutions inluding the original.
See screenies.
    34.89 KiB
Read the new FAQ.doc
Reply 1 of 10, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
I think the solution to this problem will have to wait for ages, since "no member of the group is particularly eager to put their hand there"!
Sorry, couldn't resist 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 10, by ErikGG
Sorry, couldn't resist Happy
Well I should have figured clicking the toilet would have that effect on people.
Anyways, as you can see in the screenshot the right side of the screen is missing a piece, but filled with a random leftover of previous frames.
This occurs if I use a scaler other then the normal2x, normal3x or none.
I tested it on two computers already with the same effect, so it isn't hardware related.
Erik.
Reply 5 of 10, by ErikGG
Right, the dimentions of the screen are correct and the 8 pixels from the right aren't getting refreshed every frame.
Haven't tried DOSBox's earlier then 0.65.
I'll see what they turn up.
Erik.
Reply 8 of 10, by ErikGG
You are right rcBlanke, DOSBox 0.63 doesn't show this problem. Tried the advinterp2x scaler.
Fallout 1 doesn't show this problem though in DOSBox 0.65 and up, but then I have currently no idea what res it runs on.
Erik.
