DOS CD Drivers
First post, by F2bnp
Hello this is my first post here and I was wondering if you could help me.As an abandonware fan I tried to setup a Virtual PC using Microsoft Virtual PC 2007.I also have another PC for that reason but since it takes too much space,I thought it was a good idea to try the Virtual PC.So I installed Win98 with sound blaster 16 and a Trio64V for graphics card.And now here is the problem.In Win98 DOS Mode,I installed the sb16 drivers but I don't remember how to install the cd drivers.I assume I have to edit the config.sys and autoexec.bat files.I need your help!
Thanks!
Reply 1 of 22, by franpa
elaborate on this win98 DOS mode... how did you get to there? are you running DOS inside win98? or are you pushing F8 during bootup to reach native DOS?
if its during win98 then i doubt you need any.
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 2 of 22, by F2bnp
Start\Turn Off Computer\Restart in MS DOS Mode
That's the one I'm talking about but there is no cd rom drive.Only floppy and hard drive.
Reply 3 of 22, by Kreshna Aryaguna Nurzaman
First, you need to have CD ROM driver for DOS, which could be hardware-dependent (although I think Oak CD ROM driver will work for every CD drives --it is pretty much universal). You can download an oak CD driver on this page, then you should put it in your CONFIG.SYS like this:
[config.sys]
DEVICE=C:\DOS\HIMEM.SYS
DEVICEHIGH=C:\DOS\oakcdrom.sys /D:mscd001
LASTDRIVE=F
And then you need MSCDEX.EXE, which should be put in AUTOEXEC.BAT like this:
[autoexec.bat]
LH C:\DOS\MSCDEX.EXE /D:mscd001 /l:D
EDIT: here's the link to download Oak CD ROM driver.
Kreshna Aryaguna Nurzaman.
Reply 4 of 22, by F2bnp
Hmmm thanks I will try it.
Edit...
It's not working.
Reply 5 of 22, by Kreshna Aryaguna Nurzaman
Edit...
It's not working.
Have you copy them to your hard drive, and edited your CONFIG.SYS and AUTOEXEC.BAT accordingly?
Reply 6 of 22, by F2bnp
Of course!I put them on C:\DOS
Reply 7 of 22, by Kreshna Aryaguna Nurzaman
Wait, wait. Both CONFIG.SYS and AUTOEXEC.BAT should be put on C:\ instead of C:\DOS.
Reply 8 of 22, by Jorpho
Actually, there are a couple of alternatives to the Oak Technologies driver that take up less RAM.
http://www.mdgx.com/newtip1.htm#CDROM4
Some of them can be used with DRVLOAD or CTLOAD (or a similar utility) that allows them to be loaded from autoexec.bat instead of config.sys.
http://www.mdgx.com/dos.htm
Reply 9 of 22, by F2bnp
Of course 🤣 😜
Don't think I'm a noob or smth.
Jorpho thanks for the links!They might come in handy.Will try them out tommorow.
Reply 11 of 22, by F2bnp
DosFreak you might be right.But Dosbox isn't pure DOS,it's emulation.Having pure DOS on a PC is much better.
Reply 12 of 22, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Hmm, I thought this was about running it on VirtualPC...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 13 of 22, by Kreshna Aryaguna Nurzaman
Provided you have all the necessary hardware, of course, and sufficiently low speed.
Reply 14 of 22, by collector
Except I can run more games in DOSBox than I ever could on a single real PC with DOS. DOSBox is like having several different PCs with DOS/Win3x.
Reply 15 of 22, by F2bnp
I guess you're right.Don't get me wrong, I love Dosbox (:P) but ok I thought running virtual pc would give me full speed.Seems like I will have to bring back my 166 mhz.
Reply 16 of 22, by wd
Rank DOSBox Author
DOSBox Author
If you need full speed, you're maybe better off with vmware anyways.
But full speed is, as already noted in this thread, not what you want
for dos games most of the time.
Reply 18 of 22, by Kreshna Aryaguna Nurzaman
Speaking about full speed, how about VDMS?
Reply 19 of 22, by Dominus
DOSBox Moderator
yeah, more speed with VPC, full speed with VDMS and most compatibility with Dosgames Dosbox.
It's that easy. If you want to play games choose Dosbox. Really. VDMS is severly impacted by Windows' dos prompt. VPC is crap regarding games...
