First post, by MiniMax
Rank Moderator
Moderator
If you can't find the voodoo version of tomb.exe, there are lots of places you can download it. Here are three. […]
* Stella's download page.
* Dracman's Glidos page: just use the tomb.exe file; that's all you need.
* Direct from the Eidos support site: you want the Voodoo Rush version.
The link to Eidos is broken:
http://support.eidosinteractive.com/GI/Custom … =130&platform=3
Edit: I guess this is the file to download?
http://support.eidosinteractive.com/index.php … nloaditemid=108
_________________
Reply 1 of 6, by Glidos
Aaaaaagggggggggggghhhhhhhhhhhhhh!!!!!!!!!!!!
If you want to use Glidos, then just install TR1 by using my preconfigured archive. PPPllllllllllllleeeeeeeeeaaaaaaaaassssssee!!! It makes things so much simpler.
Reply 2 of 6, by MiniMax
Rank Moderator
Moderator
Hey - Calm down Paul. I was just reporting a broken link.
(okay - I had planned on doing the manual install, because I am that kind of guy that likes to know exactly what is going on behind the scenes. But if it didn't work, I surely would have tried the preconfigured install)
_________________
Reply 3 of 6, by Glidos
Calm! Calm! Calm!... Better now. 😁
Reply 4 of 6, by wd
Rank DOSBox Author
DOSBox Author
Then remove those manual install instructions or update them.
MiniMax provided a link to the presumably new download location
of the update files, which deserves more a "Thanks, but..."
than that Aaaaaagggggggggggghhhhhhhhhhhhhh!!!!!!!!!!!!
Reply 5 of 6, by Glidos
FFS, I was only joking.
Anyway, what are you on about. My instructions say "The easiest way is to use the archive of a preconfigured Tomb Raider and Unfinished Business installation, ready for use with Glidos." Are you saying remove the alternatives? Maybe I should.
The thing about the preconfigured archive is it obviates the need for finding the voodoo version. In fact it now contains Kevin Bracey's patched version that give all the PS audio triggers. It just saves so much hassle.
Its probably the best thing to use for DOSBox users, and for dgVoodoo users.
Reply 6 of 6, by wd
Rank DOSBox Author
DOSBox Author
You have a broken link on your HP. MiniMax suggested updating the link.
