First post, by Franky r
Hi,
Basically I'm searching for a way to run a program we use (cubic) under vista.
it works fine under xp via the command line but gwon't even start under vista. I use it via a virtual pc now but I want something sleeker. When I try to run it in dosbox I get the error "this program needs windows NT to run" I'm sure this is the dos version since I use the same command on xp command line and that works.
any thoughts ?
thns in advance !
Reply 2 of 5, by Franky r
So is there no hope on getting it to work ?
Reply 3 of 5, by wd
Rank DOSBox Author
DOSBox Author
Not with dosbox.
Reply 4 of 5, by MiniMax
Rank Moderator
Moderator
Try VDOS32 - http://www.vdos32.com/
_________________
Reply 5 of 5, by wd
Rank DOSBox Author
DOSBox Author
Yes, interesting idea, might work, or a similar thing with
http://www.japheth.de/HX.html
under dosbox.
