Dosbox 0.58 for OSX?
First post, by yanosch
Hi!
Is there a binary package for Dosbox version 0.58 for MAC?
I´m running version 0.65 on my G4 800Mhz and the only game that i play is Panzer General -it´s very slow when scrolling the map so i wonder if 0.58 version could be better for playing Panzer General? Will more memory in my G4 improve perfomance with Dosbox?
Thanx!
Reply 1 of 4, by wd
Rank DOSBox Author
DOSBox Author
Is that ppc or x86?
More memory won't help (unless you're seriously low on mem).
What about the latest dosbox version?
Reply 2 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
try the 0.70 package
I don't think 0.58 can run panzer general
Water flows down the stream
Reply 3 of 4, by yanosch
It´s a PPC -The reason why i wondered if 0.58 would work better with PG is that the dosbox compability list showed that 0.58 had good PG perfomance.
I tried 0.70 and 0.72 -the PG performance is much slower than 0.65.
Is there any way to speed up the scrolling?
Thanx for quick replys!
Reply 4 of 4, by DosFreak
Did you try changing the cycles values in 0.72? I believe it was set to 3000 in 0.65 by default whereas it's set to auto in 0.72.
Not sure how this works on PPC since you can't use dynamic core in DosBox.
Make your games work offline
