video ram question
First post, by tikbalang
in general, what benefit does more video ram give? i have a P4 with onboard video that is configurable for 4, 8, 16, 32 or 64 mb.
do the features and capabilities of the card become disabled if lower vidram is used?
Reply 2 of 3, by tikbalang
so only 3d performance is affected? what about resolution and color depth? the pc will be used to store/view high res photos. thanks for the quick reply.
ESS PCI DOS Drivers
_________________
Reply 3 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
you do the math ;)
highres = 1024x768 ?
colordepth = 32 bit ?
so memory needed=
1024x768*(32/8)
I don't have a calculator here
1024 x 768 x 32 bits per pixel = 25.165.824 bits.
25.165.824 bits / 8 = 3.145.728 bytes.
3.145.728 bytes / 1024 = 3.072 KB.
3.072 KB / 1024 = 3 MB.
You will need at least twice that quantity for page buffers / buffer flipping, etc.
*** Sorrry Qbix, for editting your post ***
Water flows down the stream
