First post, by MadMadMadWorld
I'm unsuccessfully trying to run Shadow of the Comet, in the CD version, from DOSBox. Currently, both Shadow and the HPL Museum just shut down with "Divide Error", and lock DB...
I gather the error would be originally caused by a machine that was too fast, so I was experimenting with various cycle and core settings - to no avail so far... :\ Would anyone have any recommended settings for the game? Or is there something else to try and change in the config? (The game does install, by the way, and I mount it with "SHADOWCD" as the label. I tried the floppy version, too, and it runs correctly.)
I'm running 0.72 under XP, on a P4 3.4 GHz. I also tried the CVS build, but the result is the same.
Reply 1 of 7, by MiniMax
Rank Moderator
Moderator
No idea 🙁 A wild, wild shot: Don't mount as E? Only mount as C & D ? Tried older builds? Maybe one that includes the simple core?
_________________
Reply 2 of 7, by eL_PuSHeR
Another shot in the dark:
Try making a BIN/CUE image pair and use it with imagemount.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 7, by MadMadMadWorld
Hey, I just got it! 😀
I was doing it according to a suggestion for installing this game, and I was mounting it with the -ioctl parameter. For some reason, it was causing the crash. Turns out that when I get rid of that parameter and only mount the game with "mount D h:\ -t cdrom -label SHADOWCD", it works correctly. Both the game and the museum run now. 😀
Reply 4 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
maybe it tries to determine cd speed ?
but it is an interesting case
Water flows down the stream
Reply 5 of 7, by wd
Rank DOSBox Author
DOSBox Author
How exactly did you mount it when it doesn't work, and how when it works?
Reply 6 of 7, by MadMadMadWorld
mount D h:\ -ioctl -t cdrom -label SHADOWCD
and
It's really weird, though... because now I tried: mount D h:\ -ioctl -t cdrom -label SHADOWCD again, just out of curiosity... and it didn't crash. Now the game works with or without -ioctl, for some reason. I even reinstalled it to see if something happens, and all went correctly. I don't really know if I did something that could have eliminated the crash at the same time that I removed the -ioctl parameter the first time, or if there was some system issue that caused this...
Damn, I just thought now that maybe I caught some rootkit that messes with the system... :\ Oh well, off to check. RRevealer, Gmer, Ice Sword and other tools don't show anything, though...
Reply 7 of 7, by wd
Rank DOSBox Author
DOSBox Author
Hehe hope the rootkit isn't that serious 😉
The -ioctl is automatically used in 0.72, that's why i was wondering why
it would have an effect at your place. Maybe there was some additional
modification you did during installation or something, like mounting a different
drive (there are picky games around).
