First post, by Vemp
Hi all,
I've just installed dosbox 0.72 on osX, and i'm trying to get a working config for a couple games, like frontier - elite II and eye of the beholder.
The problem is I just can't get them to run in windowed mode with 2x scaling active. I've set up scaler=normal2x forced in the config, and this gets the DOS prompt window scaled up right, but when i call frontier.bat or eob.bat, the game loads, seems to switch screen mode and falls back to 1x scaling, which is way too small.
Did I miss something in the config file comments?
Current config file reads - for interested parts
[sdl]fullscreen=falsefulldouble=falsefullresolution=originalWindowresolution=originaloutput=surfacehwscale=1.00[render]frameskip=0aspect=falsescaler=normal2x forced
any hint welcome, thanks in advance 😀
