First post, by Adamas
Forgive the subject line or if its been repeated. Here's the deal, long time back i did download dosbox but my total ignorance i couldnt figure it out so i gave up. However i digress, I found a site called classicgamingpresents.com It has a good bit of dos games that you can download using XP. Works well, only there is no sound with the game (darklands) when i exit the game the dosbox window will be open and the line CONFIG:Loading settings from config file dosbox.conf MIDI:Opened device:win32 The blinking cursor will do nothing if i try to enter anything. No matter as i'm a dunce. And when i close the dosbox window i'll get an application error. I really doubt i'll be able to do anything, the music settings in the games don't work... Oh yes i believe its using a older version so that may be it,,,Just wondering on what the pros may say...thanks
Th
