First post, by psionrevo
I have compiled DOSBox 0.72 with zgcc 2.95.2 (by using distcc and big comp) under Cacko 1.23 ROM on Sharp Zaurus C-1000.
C-1000 use qtopia.
So, when I run dosbox, I get:
QPaintDevice: Must construct a QApplication before a QPaintDevice
Aborted
I understand that I must create QPEApplication object,
but maybe someone has an idea where and how I have to do it?
thanks
Reply 1 of 3, by wd
Rank DOSBox Author
DOSBox Author
Maybe have a look at other SDL apps that you/somebody got to work on the zaurus,
how their initialization code/screen setup looks like.
Reply 3 of 3, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Maybe also take a look at Exult (http://exult.sf.net), we also have a zaurus port (and we are using SDL) and AFAIK the code is in CVS. Unfortunately Exult is not one of the sources that is easy to understand right away. But, well, maybe it helps you.
