First post, by Gargantou
Hello, I have a major issue with the game called CyberJudas, I've searched the forum and tried everything I can find but nothing seems to work!
The problem is that sound skips all the time, sorta like you're listening to an old recording that is really really scratchy.
I'm running DOSBox 0.72 using latest version of DBGL under Windows XP Home SP2.
I have C: mounted as my 'DOSBOXHarddrive' folder and my CD as "Mount D: F:\ -t cdrom -ioctl.
No dice.
I've tried increasing the sound block size, changing the IRQs etc..
Any help would be highly appreciated..
Reply 2 of 2, by - Ultor -
I have the same problem too. Better: CJ does not start. At the beginning, ha was asking for the CD into drive. I fixed it someway, now it wants the audio card. He find an Adlib Gold, or something like that, but I'm unable to SAVE the settings with the CJ's "Install.exe" application.
Even disabling DosBox audio drivers has taken no effect.
I may agree to play without sound, but at least I'd like to be able to play >.>
