Reply 53720 of 57138, by Ozzuneoj
Thermalwrong wrote on 2024-07-21, 14:01:
I don't think that P601 3-pin connector is actually a fan, from where the traces route off to: https://www.vgamuseum.info/index. […]
AGP4LIfe? wrote on 2024-07-21, 01:11:
Picked up this red hot 🔥 beast Ti4600 Golden Sample recently. Anyone know to get the three pin power connector to work?? The original cooler works just fine, but I'm not getting any power from the three pin connector. Maybe it's a software switch or something?
The attachment PXL_20240721_002411431~2.jpg is no longer available
The attachment PXL_20240721_002352701~2.jpg is no longer available
I don't think that P601 3-pin connector is actually a fan, from where the traces route off to: https://www.vgamuseum.info/index.php/cpu/item … eforce4-ti-4600
I think it's more likely to be coax TV-out or something like that...
*later*
Huh, did you know a full schematic for the NV25 P80 (Geforce 4 Ti4600) board is available online?
So it's actually the connector for the stereo vision goggles:
The attachment Screenshot 2024-07-21 at 15-00-58 140-10080-0000-A04-X03 - nv25 schematic bga.pdf.png is no longer available
Good catch. And it makes sense. At that time GPUs generally didn't have any fan monitoring so they pretty much universally had 2pin fan connectors like the one along the bottom edge of the board. Just a simple power and ground.
In fact, I don't think it was until the Geforce 7000 series that we started to see more than two pin fan headers on nvidia GPUs.
Reply 53721 of 57138, by dionb
PC@LIVE wrote on 2024-07-21, 13:52:
The other is a switch (HUB?), with the possibility of connecting 10 100 and even 1000 LANs, therefore almost all PCs, lack the power supply, but you can easily find one of the same voltage (5V), at the moment I won't be able to verify this, but maybe it could be useful if you wanted to connect more than one PC.
If it supports 1000Mbps, it can't be a hub, as GbE is obligatory full duplex, which cannot be run over a hub.
This just looks like a generic unmanaged 5-port Gb switch. It could be something more exotic though, I have a similar-looking D-Link PoE passthrough switch, that can be powered by PoE and pass it through to one more device. Oh, and it's managed too. But check the type. As a rule, almost all Gb-capable switches will support 10Mbps, so should be fine for vintage stuff. I have mine networked via a Netgear GS116E, also a Gb switch, which plays nice with everything down to 10MbE cards in an XT.
Reply 53722 of 57138, by Ensign Nemo
Recently picked up a Thrustmaster Combat Gear set. The box was opened, but it looks like it's new old stock. The set comes with a "Top Gun" joystick and an "Attack" throttle. Too bad it didn't come with pedals.
The attachment thrustmaster_combat_gear_box.jpg is no longer available
The attachment thrustmaster_topgun_joystick_box.jpg is no longer available
The attachment thrustmaster_attack_throttle_box.jpg is no longer available
The joystick is fairly small, but it feels well built. It feels a lot stiffer than any other joystick I own, which I prefer. It also has a rubber part where the joystick meets the base, which feels like it could inhibit the range of motion a bit. It's hard to describe, but you have to use a bit more force to move the joystick at the ends of the axes. It doesn't really have an abrupt limit at the end of the range like other joysticks I own. Rather, the rubber starts compressing at the ends and you have to push harder into the rubber to make it move a little further. I haven't plugged it in yet, so I don't know if this would be a problem and if it could be addressed by calibrating the joystick with a less extreme range of motion.
The attachment thrustmaster_topgun_joystick.jpg is no longer available
There's not much to say about the throttle, except that it feels a little more plasticky than the joystick. Not a big deal to me though.
The attachment thrustmaster_attack_throttle.jpg is no longer available
The set also comes with Eidos's Joint Strike Fighter. I'm more into WWII flight sims, so I've never played it. Interestingly, I read in a review https://www.combatsim.com/review.php?id=317 that it was made by a demoscene group who developed an advanced terrain rendering technique.
Reply 53723 of 57138, by Kahenraz
The rubber might have hardened over the years. The feel might not be as it was when it was new.
Reply 53724 of 57138, by Ensign Nemo
Kahenraz wrote on 2024-07-22, 03:24:
Good point. Might just have to break it in a bit.
Reply 53725 of 57138, by zwrr
Paid $95 in exchange for the SC-88PRO, AC230V input, no need to modify the power supply unit, it will be added to my MIDI tower.
The attachment SC-88PRO_1.jpg is no longer available
The attachment SC-88PRO_2.jpg is no longer available
Pentium MMX233, Zida TX98-3D, 64MB, Riva 128, Aztech Waverider Pro 32-3D, HardMPU-wt
K6-III+550, FIC VA-503+, 256MB, Voodoo3 2000, Creative AWE32, HardMPU-wt
Tualatin-1.4G, QDI A10BM, 512MB, G400, Voodoo2 SLI, Creative AWE64
Reply 53726 of 57138, by Kahenraz
Ensign Nemo wrote on 2024-07-22, 03:41:
I've read that it's possible to rejuvenate certain kinds of rubber by boiling them as well.
Reply 53727 of 57138, by Ozzuneoj
Kahenraz wrote on 2024-07-22, 05:43:
There seem to be a lot of methods out there.
https://www.google.com/search?client=firefox- … ften+old+rubber
I would try the less noxious or destructive ones first myself. 😀
Warm soapy water, vegetable oil, etc....
Reply 53728 of 57138, by Ensign Nemo
Ozzuneoj wrote on 2024-07-22, 05:48:
There seem to be a lot of methods out there. https://www.google.com/search?client=firefox- … ften+old+rubber […]
Thanks. I didn't even know this was a thing you could do.
Reply 53729 of 57138, by zuldan
zwrr wrote on 2024-07-22, 04:09:
Very nice! Don’t forget to replace the battery or remove it all together.
Reply 53730 of 57138, by Veeb0rg
kolmio wrote on 2024-07-21, 19:29:
Veeb0rg wrote on 2024-07-19, 06:43:
PD2JK wrote on 2024-07-18, 09:37:
And about that, are those flathead screwdriver marks where the holder was? Ugh.. 🙁
Hope you get it running Veeb0rg !
Here are the other boards in that lot. I do plan on scavaging bits I need to get the SlotA board working from these boards. I'll pretest components as best I can and see what happens..
Allow me to open your eyes to the horrors I've seen..
Seems that left top one was mATX with Slot 1, very cool for a compact system, I'd use a modern desktop case for that.
yeah would have been had the scrap guy not destroyed it by ripping the IO off.
Reply 53731 of 57138, by zuldan
Got this ET6000 4MB (Jaton Video Magic 128) for a very late 486 build.
The attachment 91621584-63FB-4D12-9041-8896CFC13AF1.jpeg is no longer available
Reply 53732 of 57138, by Kahenraz
Ensign Nemo wrote on 2024-07-22, 06:21:
If you do boil it, use something to lift it off the bottom of the pot so that it's heated by the water and not conducting the element at the very bottom.
Reply 53733 of 57138, by Ensign Nemo
Kahenraz wrote on 2024-07-22, 14:06:
Good point. Thanks!
Reply 53734 of 57138, by AGP4LIfe?
*later*
Thank you for the great information!! Quite the bummer as it looks like it was built for that aftermarket G4 cooler. .. oh well.. back to stock it is i guess.
Cheers!
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 53735 of 57138, by PC@LIVE
dionb wrote on 2024-07-21, 20:48:
Sorry, but unfortunately I'm quite ignorant on the subject, then add the translation, the result is not always understandable.
I add a couple of images, I hope you understand more, I noticed that it has 8 ports and not 5, it could be an advantage, and maybe some of those 8 could be used for peripherals, i.e. printer or other.
Considering that the price was 0 (gift), I am interested if it can be used in some way, I hope you can advise me on how to use it, thank you very much for the suggestions, and if you have the desire and time, you can look at my page, the repairs and tests on several MBs, I hope I don't bore you, and if you want to participate, you are welcome.
Re: Test and troubleshoot PC@LIVE motherboards
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
AST Pentium Pro 200 MHz L2 256KB
Reply 53736 of 57138, by cyclone3d
AGP4LIfe? wrote on 2024-07-22, 18:27:
*later*
Cheers!
Just redo the 3-wire fan to 2-wire. You just need red and black. The yellow if for the tach which is not necessary.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 53737 of 57138, by dionb
PC@LIVE wrote on 2024-07-22, 18:29:
Your photo shows the model number of the switch: DGS-1100-08
So it's a D-Link DGS-1100-08 Gigabit Smart Managed Switch
It is very likely to be useful for you as a networks switch:
- It's an 8-port Gb switch, so you can use it to connect up to 7 devices to one network cable
- it supports speeds up to 1Gbps but also down to 10Mbps, so both your modern system(s) and vintage stuff will work
If you're not into networking that should be enough, but as it's a managed switch you can do a lot more if you want to explore:
- set a mirror port to capture all traffic to and from a device, for security or troubleshooting
- set up VLANs to segment your network (useful for keeping insecure older computers off the internet, or guests/siblings away from your systems)
- set up QoS to prioritize certain traffic on your network
You can find more information/documentation here:
https://www.dlink.com/en/products/dgs-1100-se … _reva#downloads
Reply 53738 of 57138, by weedeewee
dionb wrote on 2024-07-22, 21:31:
You do realize that another switch or router is also a device ? 😀
Do not ask Why !
Reply 53739 of 57138, by dionb
weedeewee wrote on 2024-07-22, 23:15:
Hence 7: 1 to connect to the cable from router/other switch/whatever, 7 to connect to other things. An 8-port switch increases the number of available connections by 8-1=7
