Problems with Glidos
First post, by luanswan2002
Hey I'm having two issues with Glidos!
The first being the fact that I use the unlock service properly, yet the spinning logo remains.
The second being when I run the game in opengl, in windowed mode (800 by 600), the screen is just black. But I find I can fix this little problem by, erm, dragging the window in any direction and then everything appears again, weird. This problem does not happen in directx.
I've reinstalled Glidos several times, thinking I could fix these problems like that. Is that what screwed up the spinning logo thing?
Anways I would love answers to this Paul! 😊
System details:
Intel E2160 Core 2 Duo @ 3.42 GHz
Abit IP35-E motherboard
2 GIGs 800 MHz OCZ
Windows XP
Every driver is updated
On board sound
Nvidia 7600 GT
Hope you can sort something out for me!
Cheers. šŸ˜’
Reply 1 of 19, by Glidos
Trouble is, I don't know the answer. Windowed and fullscreen mode works fine in both OpenGL and DirectX on a great variety of graphics card. The problem must be specific to your computer. If I could make something similar happen here, I could look for a cure, but I can't. OpenGL support for your graphics card could well be a little broken. Its not unheard of.
If no joy with OpenGL, why not use DirectX. That is why I provided the alternatives. If trouble with one, use the other.
Yes, reinstalling requires unlocking again, although not repayment obviously.
Reply 2 of 19, by Glidos
Hmmm, I see you mention 7600. Should be ok.
Reply 3 of 19, by luanswan2002
I did the activation thing after I reinstalled but the logo still spins awww. I rekon it's Nvidia's piece of shite drivers!!
Reply 4 of 19, by Glidos
Ah no: the drivers may explain the OpenGL problem (although nVidia generally have good OpenGL), but no way can the drivers affect activation.
Check that your GlidosID isn't changing. Also make sure you close Glidos and restart it after activation.
Reply 5 of 19, by luanswan2002
I'm using directx and it runs fine now..
this is what I'm doing tell me if i'm going wrong:
clicking "Glidos id"
copying glidos id to clipboard
go to the unlock service on the website
logging in
I enter my glidos ID (but the same glidos id is already at the bottom of the page along with 2 others?), anways I click unlock...
I copy the unlock code and press "install your unlock codes from the clipboard"
"keys installed, retart GLidos"
Do that... go into the game... start at the beginning of the waterfall level.. Glidos logo spinning, still. :<<<<
Reply 6 of 19, by luanswan2002
I'm getting really stuck on what to do with the spinning logo, just not going away at all, the Glidos ID doesn't change ever šŸ˜–
Reply 7 of 19, by Glidos
When you restart Glidos, before playing the game, check your GlidosID to see if it has changed. Some people have had problems with the ID changing depending on whether they are on the internet or not.
Reply 8 of 19, by luanswan2002
It says now I've used my allocation of unlock codes? How do I fix this? Sorry I'm having computer hardware problems at the moment and I've reinstalled Windows and made hardware changes a lot.
Reply 9 of 19, by Glidos
Try again now.
Reply 10 of 19, by femios
Hello!
I don't know too much about computers. I just enjoy playing Tomb Raider. That's why I bought the Glidos Unlock Codes and it worked fine two times -- and it was magnificent --- but then the third time i got the logo again. The probleem seems to be that my Gildos ID number changes every time I turn on the program, so after two times I used up the.... whatchamacallit.
Is there a solution for this problem? I read something about internet, should i turn it off before i use glidos? and how long do i have to wait then until i can play without the logo again?
thanks for the help,
f.
Reply 11 of 19, by Glidos
I can add to your allocation easily enough, but that isn't going to help much if your GlidosID keeps changing.
The only known problem like this one affecting Glidos is the ID changing when your computer's network configuration changes. One user found that their ID changed according to whether they had their modem turned off or on.
Is it that you are seeing two different IDs, or have you seen several?
Reply 12 of 19, by femios
Yes, I've seen several. It's a different code each time I turn the program on. I can not use my unlock code more than once..
I'll try turning internet off next time i can use a code again...
Reply 13 of 19, by Glidos
Try running this tool and send me back the output. Try it twice, shutting down the computer inbetween the two runs.
Reply 14 of 19, by Glidos
Here's the main executable for v1.40b of Glidos. I think this will cure your problem. You will also need to tell me your Glidos account email address by private message, so that I can give you some more unlocks.
Reply 15 of 19, by vistisen
I seem to be having the same problem. I installed glidos and used up one code, then I made the mistake of installing Vista service pack1 😲
After reinstalling everything because SP1 FUBARed my installation I used the second code. But yesterday VDOS32 suddenly needed to unlock itsself again , and then my Gidos ID had changed. But I can not unlock it again as I have used my two codes.
Reply 16 of 19, by Glidos
Was it you I just sorted out by email?
Reply 17 of 19, by vistisen
No, It was not. I have not emailed you because the website said to use this forum. But i can if you want me to, I forgot to say that I am using version 1.40
Reply 18 of 19, by Glidos
Yes please. If you can let me know the email address associated with your account, either by email or private message, then I can up your allocation.
Has your Id stopped changing?
Reply 19 of 19, by vistisen
I have sent you a pm
