First post, by Radinor
I have the files from my old MS-DOS 6.20 install disks on my computer. I'd like to make a bootable floppy image file, so dosbox could boot MS-DOS 6.20, and I could install it on a virtual hard drive.
The problem is, that if I simply make a floppy image file with winimage, and copy the files of the MS-DOS install disk into it, it won't make it bootable, even though it has io.sys, msdos.sys and command.com.
Directly making image files from the ms-dos disks is not an option, because the disks got ruined 3 years ago.
How can I make a bootable floppy image?
Reply 1 of 4, by DosFreak
If you have Windows XP you can make a bootable image when you format a floppy.
or you can download FreeDOS which has bootable floppies/CD.
or you can find a copy of MS-DOS easily on the internet.
Make your games work offline
Reply 2 of 4, by Radinor
I got a little further. I found out that there's an option in winimage to change the properties of the boot sector on the image file. I found an MS-DOS 6.22 boot sector type, and I modified the boot sector to that.
Now, the image still doesn't start, but now it displays the "Non-system disk or disk error" message at boot, even though the image contains io.sys, and msdos.sys.
Maybe the problem is, that the disk contains the files of MS-DOS 6.20, but the boot sector of the image is 6.22? There wasn't an option for a dos 6.20 boot sector, only for a 6.22 one.
Reply 3 of 4, by Radinor
I found MS-DOS 6.22 disk images on the internet and they work!
Looks like I'll use 6.22 instead of 6.20, but the important thing is that it works.
Reply 4 of 4, by eL_PuSHeR
It's even better for you. I think 6.22 is a bug-fixed version.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
