Printing Problem
First post, by Lizard
Hi Community!
I know that this question is in some boards but all these information what i found there wasn´t helpfull.
The Printer Dialog is comming but the printer i selecte don´t want print.
I searched and seached but i couldn´t solve this problem.
Please help me.
I use the newest version from this side :
http://ykhwong.x-y.net/cvs/frame.html
Thanks for your help!
Lizard
Reply 1 of 16, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
ctrl+f2 after the program is done printing
1+1=10
Reply 2 of 16, by Lizard
Thanks for answer, but it doesn´t work.
How can you print?
What i´m doing wrong?
in windows i do this:
net use lpt1: \\servername\printer
and in dosbox i do this:
copy file.xyz lpt1
but it doesn´t work 🙁
Reply 3 of 16, by wd
Rank DOSBox Author
DOSBox Author
copy file.xyz lpt1
And it still doesn't work if you send the feed end (ctrl-f2 as hal said,
but maybe check that in the mapper or remap it to something that you
are absolutely sure is a free key combination).
Why don't you print the file in xp anyways?
Reply 4 of 16, by Lizard
this is an dos application and the user shouldn´t know that xp is running behind.
can i print without pressing ctrl + F2 ?
Reply 5 of 16, by wd
Rank DOSBox Author
DOSBox Author
Yes, but if the page isn't full you won't see what you printed
if the file you sent to the printer was less than a complete page.
Reply 6 of 16, by Lizard
Is there no chance to print small files?
Reply 7 of 16, by wd
Rank DOSBox Author
DOSBox Author
Well it works fine, just if you wanna see what you printed you got to hit ctrl-f2.
Reply 8 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
well we could (if we supported the printing builds of ykhwong, (which we don't! (we have one of ourself which we do support though))) add a timer to print a page if there hasn't been any new data for 10 seconds.
Water flows down the stream
Reply 9 of 16, by wd
Rank DOSBox Author
DOSBox Author
In my stuff is some logic that it feeds the page if the program terminates,
don't know if that works with plain copy> though but it was working
quite nicely for me.
Reply 10 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
I'm not entirely sure. I think the forced pagefeeding was in the dos_terminate code.
Which isn't used for internal commands like copy
Reply 11 of 16, by Lizard
is there a chance to print smal files or not?
i can´t see an answer^^
Reply 12 of 16, by wd
Rank DOSBox Author
DOSBox Author
Maybe try it with reading or something similar.
Reply 13 of 16, by Lizard
i shoult add an timeout but how can i do this?
which command i need?
Reply 14 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
the answer:
Printing builds of ykhwong are NOT supported by the dosbox authors.
So you have 2 options.
1. You try to convince somebody to improve the ykhwong printer code.
2. You use the printer build of the DOSBox authors.
Both options might end up costing you money or other things to persuade people.
Maybe somebody will improve the printer build from ykhowng for free. Who knows ?
Reply 15 of 16, by Lizard
Big Thanks for help
Reply 16 of 16, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
When using ykhwong's build you have to open the dosbox.conf file and set disney=false.
1+1=10
