DOSBox on Linux Ubuntu
First post, by Why-Fi
Does DOSBox run on Linux Ubuntu 7.10? Please tell me as soon as possible, I want to run a DOS program on my Linux Ubuntu 7.10, but it doesn't have Internet connection, so I can't use synaptic to get an emulator... 😢
Why-Fi, the DOS lover #1...
Reply 1 of 5, by tannerstevo
Yes, I have DOSBox 0.71 installed on my linux machine, also running Ubuntu 7.10. I used synaptic to install mine, so I'm afraid I can't be of much help when it comes to a manual install though.
Reply 2 of 5, by rcblanke
You may want to look at DBGL for Linux which also contains a 0.72 DOSBox binary for Ubuntu.
Reply 3 of 5, by Gurowner
$ sudo apt-get install dosbox
Is not that hard.
Reply 4 of 5, by TeaRex
Can you apt-get with no internet connection?
If you jave the gcc Compiler and the associated tools, and SDL, installed on your Ubunutu, you only need the DOSBox source code. Self-compiled stuff is usually going to work best since it uses all the right libraries etc.
Try by typing
gcc --version
and also
sdl-config --version
into a console window, if both give you a version message (rather than "command not found") you probably have the needed tools.
The source is straightforward to use: Unpack it
tar xvjf filename.tar.bz2
cd dosbox-0.72 (or whatever it's named, see output of command above)
./configure
wait a minute
make
wait some more minutes
sudo make install
That's all. For more info read the included README file.
tearex
Reply 5 of 5, by leileilol
Yes. You can burn packages to a disc then use the cd-rom drive as a source.
long live PCem
FUCK "AI"
