First post, by kriscorrie
Hello, im attempting to play Theme Hospital on MAC using dosbox.
Ive got everything working fairly easily, but the games seems incredibly slow and jerky, its only really playable on low res mode.
Im wondering if anyone has any ideas for making this run a bit more smootly, given the age of the game and the fact ive got a fairly new mac, id expect the hardware is capable of handling it!
thanks in advance
Reply 1 of 3, by IIGS_User
Try to play along with cycles=auto or cycles=max.
Klimawandel.
Reply 2 of 3, by kriscorrie
hi there, thanks for the help,
ive tried both with little or no obvious difference!
any other suggestions welcome
Reply 3 of 3, by Zorbid
If you have a PPC Mac (G3 or G4), as I assume from your other post, you're probably out of luck with Theme Hospital.
Try increasing the frameskip, and refer to the DOSBox guides in the other section of the forum for further help.
