First post, by boludes
Hello, I'm from Argentina, and I have a problem with de reproduction of the capture (.avi with Ctrol + Alt + F5), and I can't watch the video. I wonder if anyone knows one, or know the solution to Windows Media Player. Thank you so much. 😉 😊
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
I think there is some documentation in the startmenu entry of dosbox
Water flows down the stream
Reply 2 of 2, by the fall guy
1. Install the zmbv video codec from the \zmbv subfolder in your dosbox folder (there's a readme to tell you how).
2. If you already did so and it still doesn't work, check your desktop color depth is at least 32 bit (btw, that's missing in the readme 😀 )
3. As a workaround, you could use RAD video tools to convert the avi to a video format that you know for sure will work with your media player software (this can take lots of time, better try on a short record first to see if it works at all).
