First post, by Zezinho
hi, it is my first post here.
I've done some linux rpm packages containing an abandonware game and the good shortcut to launch it easily.
All is working nicely except for some very old things that need to be slowed down. For those ones, I need a way to launch dosbox from the command line with 250 cpu cycles per example.
Would it be possible to add this feature? Or does it exists another way to do it?
Thanks
Reply 1 of 2, by wd
Rank DOSBox Author
DOSBox Author
I've removed that link, i'm sure you are aware that distributing these
games is not allowed in most countries.
About your problem: check out stuff like the -c parameter of the
dosbox executable, like
dosbox -c "cycles 500"
Reply 2 of 2, by Zezinho
Sorry for the link, I didn't knew about this forum policy. Anyway, thanks for the answer, it was the good one. I added the line to the batch file.
