Change Virtual Drives
First post, by masterofhisdomain
Is there any easy way to change the inital virtual drive that dosbox uses? (I.E. Z:\ to like I:\) ? I did not want to have to download source, change, and then compile, if there was an easy way.
I have checked all the usual avenues, readme, command line switches, google..... I would hope that I am just missing something easy.
Thanks,
Masterofhisdomain
Reply 1 of 4, by MiniMax
Rank Moderator
Moderator
Nope. There might be an old version floating around that does not use Z as the internal drive.
_________________
Reply 2 of 4, by Neville
Depending to what you really want to accomplish with that, editing the AUTOEXEC section of the DOSBOX.CONF should suffice.
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
i made a public patch for that. but it does involve compiling dosbox.
either you do it (there are guides for it in the wiki) or you get somebody to do it for you.
Water flows down the stream
Reply 4 of 4, by masterofhisdomain
I found it in the patches. Thanks, I will try to setup a machine to compile this on.
Thanks,
Masterofhisdomain
