First post, by lagunalore
Hi, I want to run Alone in the Dark through the Dosbox but it gives me a problem with the cd-rom, saying: CD not found, no cd-rom driver. Has anyone had the same problem before?? Thank you!!
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
well did you mount your cdrom drive as cdrom in dosbox
(e.g. mount d d:\ -t cdrom)
Water flows down the stream
Reply 2 of 3, by lagunalore
sorry, i forgot to tell that, yes I loaded it by writing mount d d:\, but I think it's not the same, now i have tested the game and it works, thus when the character walks it stops a little, but don't think anything can be done for this problem. Thank you very much!
Reply 3 of 3, by eL_PuSHeR
Your forgot to add the -t cdrom switch to cd-rom mounting command.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
