Who can explain this?
First post, by eL_PuSHeR
I've noticed that sometimes some game(s) will run better if using VDMSound withouth the Launchpad. Why is this? I mean even selecting same parameters for Launchpad of those that are inside the INI file. ???
Reply 1 of 3, by HunterZ
I've noticed this as well. Specifically with the game Bio Menace (which now runs fine under DosBox though), the auto-detection hangs no matter what if you use LaunchPad, but seems to work most of the time if I use VDMSound without LaunchPad.
Reply 2 of 3, by Nicht Sehr Gut
Originally posted by eL_PuSHeR I've noticed that sometimes some game(s) will run better if using VDMSound withouth the Launchpad.
Specific titles? Specific effects?
All I can think of is the PopF bug and it's work-around.
I'm pretty sure that part of it would have to be that the GUI has more features implemented. EMS, for example, is enabled by default with the GUI.
Reply 3 of 3, by vladr
"Run with VDMS" also has EMS enabled.
The only difference between "Run with VDMS" and LaunchPad, that I can think of, is the default AdLib synthesis rate (44kHz in LPad, 11kHz in VDMS.INI/RunWithVDMS)
V.
