First post, by OLMi
Hi all
I'm using dosbox 0.72 and it's working great. But I want to use an old application which is using the program "more" from dos 6.22
More is not iplemented in dosbox and if I start it from the dos 6.22 folder it's telling me "wrong dos version"
Is there a way to get this and other old Dos 6.22 applications running?
Or is there a way to use Dos 6.22 instead of built-in Dos?
Thanks
OLMi
Reply 1 of 4, by wd
Rank DOSBox Author
DOSBox Author
ver set 6 22
Reply 3 of 4, by OLMi
Ok, thanks to you both
The "ver set" makes sense. I will try it out in the next few day.
And thanks about "less", but it's not only this application. I probably also need others from dos 6.22
Reply 4 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
just know that you can't do:
dir | more
as | isn't supported
Water flows down the stream
