Bertie3
First post, by METALAARON
Hello,
I am trying to run a basic old DOS program called Bertie3 on my Mac.
http://selfpace.uconn.edu/BertieTwootie/bertie3.ZIP
If anyone could help me I would be much obliged
Reply 1 of 8, by MiniMax
Rank Moderator
Moderator
Seems like it runs right away. No installer, no nothing. Just unzip and drag the BERTIE3.EXE to the DOSBox icon.
_________________
Reply 2 of 8, by METALAARON
I can't drag it to the DosBox icon! Nothing happens 🙁
Reply 3 of 8, by MiniMax
Rank Moderator
Moderator
Hmm. Don't have a Mac, so someone else will have to explain why the Mac don't support drag'n'drop.
_________________
Reply 4 of 8, by METALAARON
Sorry I thought it was obvious when I said Mac that how it runs on Windows is irrelevant.
Can any Mac users help?
Thanks!
Reply 5 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
maybe use a mac os x frontend for dosbox.
Water flows down the stream
Reply 6 of 8, by wd
Rank DOSBox Author
DOSBox Author
No it isn't.
Reply 8 of 8, by IIGS_User
You can do it this way, I checked it before posting:
1) Open the PC game's Information window (or just do a right click on it)
2) Select "Open with...", choose "Other application"
3) In the upcoming dialog, activate "All Applications" to enable all applications available (DOSBox isn't selectable with standard "Recommended applications")
4) Select the DOSBox application
5) Do a double-click onto your PC game to start it with DOSBox
6) DOSBox will mount the folder of the PC game as drive C: and start the game.
Klimawandel.
