First post, by graymachine
I'm having a problem that is probably pretty simply, but I can't seem to find a solution no matter how much I check faqs. I am running DOSbox on a Mac Powerbook. I've install the program and can successfully mount the directory my games are in. I've even explored the files in the X-COM folder by use of the dir command, but I cannot get the game to run. Everytime I type in ufo or ufo.exe I get an error message saying 'This program cannot be run in DOS mode'. Knowing that X-COM is a DOS game (at least I can run it from DOSbox on PCs) I'm not sure what the problem is, aside from the possibility that I am using a Mac. Any help with this problem would be greatly appreciated.
