First post, by TheDude
hi,
I don't know if feature requests can be made here. I think a key combination that kills the current running game in dosbox and goes back to the prompt would be very handy.
I hope this can be added in the next release.
Reply 1 of 11, by wd
Rank DOSBox Author
DOSBox Author
Close dosbox and restart it, takes a fraction of a second.
Reply 2 of 11, by TheDude
If you want to test much games after each other, closing-restarting is really annoying. that's why this feature request 😀
Reply 4 of 11, by TheDude
then please tell me how to test games the right way because you only have 2 choices: exit the game itself or close dosbox.
what other way do you have in mind ?
Reply 6 of 11, by TheDude
ermm I just said my feature request would make it possible not to do this for each game because it's annoying if you test much games.
so what's your point??
Reply 7 of 11, by Zachariah
Use a dosbox frontend (see that sticky topic), and close the games by closing dosbox.
Mounting directories manual in dosbox takes about the same time as making a game profile, but once you got a game profile, you can start the game again in just 2 or 3 mouse clicks.
Reply 8 of 11, by DosFreak
Even closing games using the quit capability in the game itself you cannot be sure that the game cleaned everything up on quitting which is why alot of times you had to reboot in DOS on a real machine when you wanted to play another game. Now you want to add a function to quit the game that isn't supported by the game itself and then run another game.....and you want to do this for compatibility testing of games.....
See the problem here?
Execute DosBox and launch the game, if you don't want to quit the game normally then hit CTRL+F9 and then launch DosBox again.
Compatibility testing isn't about just loading games and testing away, there is alot more to it than that.
Make your games work offline
Reply 9 of 11, by wd
Rank DOSBox Author
DOSBox Author
Either way it won't be added any soon.
Reply 10 of 11, by TheDude
no, there is no problem because the developers of dosbox can make sure that 'kill game' command initializes dosbox the same way as if you first booted it (initialization of all variables, objects, ... in the source code just like they are initialized/created when dosbox first starts).
Reply 11 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
maybe when we have savestates that you restore the starting state.
but until then there is no intention of adding it
Water flows down the stream
