Color changes in DosBox
First post, by silversmith
Something really odd in DosBox 0.72.
After adjusting and saving the 'dosbox.conf' file, my DOS Pascal program runs normally full screen under VISTA. However when I close and reopen DosBox and my program, the program has completely abnormal colors! (It is a spreadsheet-like program, not a game).
If I reopen and re-save the 'dosbox.conf' file, the next time I run DosBox/DOS Pascal program, colors are fine. But re-running, gives the abnormal colors again.
Any suggestions you may have to make DOSbox hold the normal colors I get only one time after saving the 'dosbox.conf' file would be greatly appreciated.
Thank you.
Peter Silversmith
Reply 2 of 3, by eL_PuSHeR
[Moved]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 3, by silversmith
Thank you -- it seemed to work.
Peter S
