First post, by haMid
hi, i was installed dosbox 0.72 on windows vista in my laptop (sonyvaio)
when i run fullscreen dosbox it dose not act fullscreen! in fact its window show fullscreen but content stay in minimize and set center of display window 🙁
please help me how can i fix this problem?
Reply 1 of 3, by general_vagueness
This problem is a part of Vista, it doesn't play well with console-type applications. I read a thread like this around here somewhere, you can probably find the answer there. If not, it might be a setting in DOSBox.conf
You cannot fall off the floor.
If you look hard enough, you'll find something you don't like.
How to ask questions the smart way
How to become a hacker
How to answer smart-alec questions
Reply 2 of 3, by avatar_58
Has very little to do with Vista. Read the readme and you'll get instructions on how to use scalers. Use directdraw as your output and set the fullresolution.
Reply 3 of 3, by general_vagueness
right, I forgot
anyway, the solution is to edit dosbox.conf, and it is true Vista "doesn't play well with others", especially "legacy applications"
in the very first section of the file, there's a line that says "fullresolution=[something]", changing that should make it the size you want, probably one of these:
320x240
640x480
800x600
768x1024
