First post, by rin23a
hi everyone, im trying to install xcom apocalyse and constructor. I have dosbox and vista. but every time I get thru the install it says that the cd isnt in the cd drive or says it cant detect a cd-rom.
Can anyone please help
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
60 Seconds Guide to DOSBox.
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 2 of 3, by eL_PuSHeR
[Moved]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 3, by Aner-Dyfan
Actually I think constructor had this 'no CD inserted error' back when it was running on a DOS machine. But by now that might be an implanted memory, since it was released around 13 years ago.
The closest thing I've found is this topic on megagames. Which alas doesn't address the issue I have with the 95 installation of Constructor, which just black screen crashes on me. I also don't really understand olldbg that well which probably doesn't help.
Anyway I've PMed the guys on megagames forum about the working *.exe, but not sure when/if I will get a reply. Other than that the only lead is the 'Backlash DOS release' which lead me to a no-CD crack which doesn't want to work for me.
