Screen capture movie
First post, by Jack
This really doesnt work for me. It logs it saying that it has started recording, then when I press CTRL ALT F5 it says stopped and saved in /capture, but the folder is always empty and the video file is nowhere to be seen on my PC. I run on Vista home premium and I generally dont know what to do so was hoping someone could help me out. Ive tried searching the forums and the READ ME but came across nothing. Thanks in advance!
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
try changing the capture directory to some other location.
Water flows down the stream
Reply 2 of 2, by Jack
Ah I see, worked after I had specified an actual file path in the config by running as admin. Thanks for the speedy reply!
