Resize window
First post, by Mosquitos
Hello,
Is it possible to resize the window screen into bv 800x600?
I'm not talking about fullscreen here.
I mean the windows window.
Reply 1 of 5, by darkgamorck
In your dosbox.conf file there is a line with the key, "windowresolution". You can change the value behind that to change the size of the window i.e.:
windowresolution=800x600
However your currently selected output mode will need to support the scaling. Different output modes like opengl or overlay might yield better results depending upon your hardware configuration.
Oh and try the readme file included with DOSBox. It's got all of this wonderful information and then some!
Reply 2 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
yes.
It has been discussed a few times recently in this specific forum.
Perharps browsing a few threads might help you out.
Water flows down the stream
Reply 3 of 5, by Mosquitos
darkgamorck wrote:
In your dosbox.conf file there is a line with the key, "windowresolution". You can change the value behind that to change the s […]
Hmm if i try that then nothing happens 🙁
Reply 4 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
did you read the other things he wrote ?
(hint output=ddraw)
Reply 5 of 5, by Mosquitos
(hint output=ddraw)
Thanks
