First post, by mary55908
I installed DOSBox, mounted the game, and after jumping through a couple of hoops I got it to play... there is no sound.
My issues thus far:
I'm Running Windows XP
The Directory is set up as follows:
C:\MONKEY\MONKEY.EXE is the setup program for Monkey Island 1 & 2
The files to initiate gameplay are located in subdirectories:
C:\MONKEY\MONKEY1\MONKEY1.EXE
C:\MONKEY\MONKEY2\MONKEY2.EXE
The first time I mounted the game, I ran the setup file. When I tried to save my configuration (set to soundblaster) within the emulated program, said program crashed at which point DOSBox displayed the error message:
ERROR: error opening .ini file
So I loaded ...\MONKEY1.EXE which produced the error message:
No CD-Rom drive or MSCDEX not installed
I decided to try and pretend that my C:\MONKEY\ directory was really a cd rom drive so I mounted it with -t cdrom
I still received the error:
When I tried to run the setup program, however when I ran ...\monkey.exe the game worked... but with no sound, which is why I was using DOSBox in the first place.. any suggestions? Did I miss something?
EDIT: Also, I have searched high and low, I found one thread in this forum concerning this game, but it didn't help and the person didn't state their problem very clearly, and it was ultimately useless. I have done various searches on google to no avail...
*Note, I am able to save the configuration when I run the setup program in my Windows XP environment
