First post, by rogertu
I have searched thru the posts and understand that you need to alter windowresolution=original
output=surface
to say 600*480 and ddraw respectively. I then see in the posts the original poster says "yeah - works great thanks"
Well it is not making any difference for me. Am i looking at the wrong thing.
I have a plain DOS program (not a game) that runs in text mode (80*25)
and the window is very small. Can I make it any bigger ???
I have tried the above on 3 different machines (both XP & Linux) with varying video cards (ATI & NVIDIA).
Tanking you in advance
Reply 1 of 7, by wd
Rank DOSBox Author
DOSBox Author
textmode (vga in dosbox) is 640x400
Reply 2 of 7, by ADDiCT
Try "output=ddraw" on windows. It's scaling text screens on my system ("windowresolution=800x600").
Reply 3 of 7, by rogertu
That is what I have done and it does not work on any of mine ????????
Reply 4 of 7, by MiniMax
Rank Moderator
Moderator
So... You have tried output=surface and ddraw. Means there are 4-5 others to try.
_________________
Reply 5 of 7, by rogertu
Yeah.. I hav tried all possible combinations in both XP and Linux and still the window stays the same size. Dosemu will adjust the window size depending on what font it uses. Is it maybe something to do with that ????
Reply 6 of 7, by MiniMax
Rank Moderator
Moderator
You wrote "600*480". It must be with an 'x', not a '*'. So try
windowsresolution=600x480
_________________
Reply 7 of 7, by rogertu
Bingo...Thats what I was after
Thank you very much for your patience
