First post, by wavedash
I'd like to try using a wired Xbox 360 controller with dos programs that require a joystick, but the default mapping of axes is nonsensical (uses the triggers as default x axis). Is it possible to remap those axes to the thumbsticks?
Using ver 0.72. The emulator reports that the controller has 5 axes, 10 buttons, and one hat switch.
Reply 1 of 1, by wd
Rank DOSBox Author
DOSBox Author
Triggers as axes sounds pretty bad, but maybe check out the mapper
(see the readme for some examples) if you can adjust the stuff.
