First post, by kinglerch
I have looked high and low for an explantion on this subject, but I guess it is too cryptic a search term.
I have an old ISA card I need access to in dosbox through io ports. The ports that the ISA card uses is 0x240 (through 0x25F). I have already enabled the ports in XP and can read and write in windows, but these ports are not accessible through dosbox.
Seeing that the soundblaster, serial, and lpt ports are accessible through dosbox, 0x240 should be able to be made available. But I couldn't find out information on how to do this.
How can I enable port 0x240 in dosbox?
Thanks for your help!
